查看: 1570|回复: 2
[求助]菜鸟求助
发表于 2006-12-25 09:49:00 | 显示全部楼层 |阅读模式
VBA的语句在VB里面能用吗,
发表于 2006-12-25 09:59:00 | 显示全部楼层
不能照搬,需作一定的修改方可!
发表于 2006-12-25 11:25:00 | 显示全部楼层
通用的VB起动Autocad程序如下:
Public Sub AutoCADConnect()        '连接AutoCAD
On Error Resume Next
Set obj_Acad = GetObject(, "autocad.application")
If Err Then
   Err.Clear
   Set obj_Acad = CreateObject("autocad.application")
   If Err Then
      Err.Clear
      MsgBox "不能运行AutoCAD,请检查是否安装!", vbOKCancel, "警告!"
      Exit Sub
      End If
End If
obj_Acad.Visible = True
Set obj_Doc = obj_Acad.ActiveDocument
Set obj_ModelSpace = obj_Doc.ModelSpace
MsgBox "运行结束!", vbOKOnly, "工程1!"
boo = True
End Sub
再将VBA程序的thisdrawing 替换为obj_ModelSpace
再对dim 定义的线段,圆等,如 dim objLine As AcadLine 替换为dim objLine as Object
80%的VBA程序在VB程序中都能正常运转
GMT+8, 2025-12-1 04:11 , Processed in 0.128182 second(s), 23 queries , Gzip On.
