查看: 1387|回复: 3
文件操作
发表于 2006-12-25 10:32:00 | 显示全部楼层 |阅读模式
请问一下:如何对文件进行写操作。(要求:打开一个文件,删除原文件中的内容,再写入新内容到文件中去)
发表于 2006-12-25 11:46:00 | 显示全部楼层
(open fn "w")就行。
 楼主| 发表于 2006-12-27 20:13:00 | 显示全部楼层
能给一段源代码吗?
发表于 2006-12-27 22:19:00 | 显示全部楼层
;;;= 读取文件到表中 =
(defun fcp::readfile (filename / fileobj str outlist)
  (setq outlist nil)
  (if
    (findfile filename)
       (setq fileobj (open filename "r")
      str     (read-line fileobj)
       (while (/= str nil)
  (setq outlist (append outlist (list str))
       (close fileobj)
     (alert (strcat "文件不能打开!请查询\n"
      filename
      "这个文件是否存在?"
  outlist
;;;= 将表中的内容写入文件 =
(defun fcp::writefile (filename inlist intype / fileobj outlist)
  (setq outlist nil
 fileobj (open filename intype)
  (if fileobj
      (mapcar '(lambda (x) (write-line x fileobj)) inlist)
      (close fileobj)
      (setq outlist t)
     filename
     "文件名是否正确?"
  outlist
;;;= 重写文件 =
(defun fcp::writefilew (filename inlist)
  (fcp::writefile filename inlist "w")
;;;= 改写文件 =
(defun fcp::writefilea (filename inlist)
  (fcp::writefile filename inlist "a")
GMT+8, 2025-11-23 11:35 , Processed in 0.182454 second(s), 25 queries , Gzip On.
