帖子
查看: 2111|回复: 3
请问在lisp中怎么用command 命令改变标注文字的大小??
发表于 2003-4-7 14:22:00 | 显示全部楼层 |阅读模式
???rt!
发表于 2003-4-7 15:50:00 | 显示全部楼层
(setvar "dimtxt" 数值)
发表于 2003-4-7 15:59:00 | 显示全部楼层
这是对标注样式的修改,不能对选中对象单独修改,我查不到标注DXF组中文字高度,不
这是对标注样式的修改,不能对选中对象单独修改,我查不到标注DXF组中文字高度,不知是不是没有[br]
发表于 2003-4-7 17:08:00 | 显示全部楼层
Specifies the height for the dimension or tolerance text
Specifies the height for the dimension or tolerance text.
Signature
object.TextHeight
object        Dim3PointAngular, DimAligned, DimAngular, DimDiametric, DimOrdinate, DimRadial, DimRotated
, Tolerance
The object or objects this property applies to.
TextHeight        Double; read-write
The height for the dimension text.
System variables
This property overrides the value of the DIMTXT system variable for the given dimension.
Remarks
The initial value for this property is 0.1800.
If the current text style has a fixed text height, this property is ignored.
GMT+8, 2025-4-7 04:19 , Processed in 0.172909 second(s), 25 queries , Gzip On.
