查看: 2964|回复: 4
(原创)标注图层的转换等程序
发表于 2007-1-2 23:13:00 | 显示全部楼层 |阅读模式
;;复制标注,移动标注,改变标注的图层,skydie,20061209
(defun c:sdim ()
   (princ "\n请选取对象...")
   (setq kk (ssget))
   (setq  n(sslength kk))
      (setq k 0 f (ssadd) kkk 0)
      (repeat n
            (setq ee (ssname kk k))
            (setq en (entget ee))
            (setq dd (cdr (assoc 0 en)))
            (if (= dd "DIMENSION")
                      (setq f (ssadd ee f))
                      (setq kkk (1+ kkk))
               (setq k (1+ k))
      (if (> kkk 0)
                (initget "c C m M L l")
                (setq tt (getkword "\n复制(c),移动(m),改变图层(1),<Enter默认为复制>:"))
                (if (= tt nil ) (setq tt "C" ))
                (setq tt (strcase tt))
                (cond (( = tt "C") (command "copy" f "" pause pause))
                      (( = tt "M") (command "move" f "" pause pause))
                      (( = tt "L") (progn
                                           (setq newla (getstring "\n输入新图层名:"))
                                           (setq chklay (tblsearch "layer" newla)) (if (= chklay nil) (command "layer" "n" newla  "c" "5" newla "Lw" "0.1" newla "" ))
                                           (command "chprop" f "" "LA" newla "")
                (alert" 警告:没有标注尺寸!")
发表于 2007-3-2 14:41:00 | 显示全部楼层
这个程序一点也不实用,
发表于 2011-4-21 15:29:36 | 显示全部楼层
发表于 2011-8-30 11:32:07 | 显示全部楼层
我觉得要是能用鼠标滚动修改标注文字的大小就好了
发表于 2011-8-31 08:54:23 | 显示全部楼层
好多都有....................
GMT+8, 2025-5-24 15:49 , Processed in 0.197282 second(s), 27 queries , Gzip On.
