查看: 3177|回复: 0
三维管道空视图的画法-带弯头处理方法
发表于 2007-1-3 13:04:00 | 显示全部楼层 |阅读模式
  '连接AutoCAD
  If boo = False Then
     AutoCADConnect
  End If
  'Microsoft.Jet.OLEDB.4.0引擎,运行ACCESS2000;
  CreateConnection ("directory.mdb")
  '设置rst1数据集,目的得到无重复的管段号
  Dim rst1 As ADODB.Recordset
  Set rst1 = New ADODB.Recordset
  rst1.CursorLocation = adUseClient
  rst1.Open "SELECT DISTINCT PipeLineNo FROM PipeLine", cn, adOpenForwardOnly, _
            adLockBatchOptimistic, adCmdText
  Dim point1(0 To 2) As Double, point2(0 To 2) As Double, point3() As Double
  Dim ii As Integer
  Dim Str_Handle() As String
  Dim txtRst1 As String
  Dim Ent As Object
  Dim LineStart As Variant, LineEnd As Variant
  Dim ArcStart As Variant, ArcEnd As Variant
  Dim Cir As Object
Do Until rst1.EOF '循环无重复的管段号
  txtRst1 = rst1.Fields(0)
  SetLayer (txtRst1)
  Set rst = New ADODB.Recordset
  rst.CursorLocation = adUseClient
  rst.Open "SELECT DISTINCT * FROM PipeLine where PipeLineNo = '" & txtRst1 & "' Order by ID", cn, adOpenForwardOnly, _
  '必须用Order by ID,否则会产生Handle标识不连续,无法执行fillet命令。
  rst.MoveFirst
  Dim Command As String, RR As Double
  RR = rst!Dn * 1.5
  Command = "fillet" + Chr(10) + "R" + Chr(10) + Trim(Str(RR)) + Chr(10) + Chr(10)
  obj_Doc.SendCommand Command
  ReDim Str_Handle(rst.RecordCount) As String
  ii = 1
  Do Until rst.EOF
    point1(0) = rst!pointX0: point1(1) = rst!pointY0: point1(2) = rst!pointZ0
    point2(0) = rst!pointX: point2(1) = rst!pointY: point2(2) = rst!pointZ
    Set Ent = obj_ModelSpace.AddLine(point1, point2)
    With rst '处理字段,可视性好。
      .Fields(3).Value = Trim(Ent.Handle)
      .Update
      .MoveNext
    End With
    Str_Handle(ii) = Trim(Ent.Handle)
    ii = ii + 1
  Loop
  rst.UpdateBatch (adAffectAllChapters) '批量更新数据库
  rst.MoveFirst
  For ii = 1 To rst.RecordCount - 1
    Command = "fillet" + Chr(10) + "(handent " & Chr(34) & Str_Handle(ii) & Chr(34) & ")" & Chr(10) + "(handent " & Chr(34) & Str_Handle(ii + 1) & Chr(34) & ")" & Chr(10)
    Dim nn As Integer
    nn = obj_ModelSpace.Count - 1
    Set Ent = obj_ModelSpace.Item(nn)
    ArcStart = Ent.startPoint
    ArcEnd = Ent.endPoint
    Set Cir = obj_ModelSpace.AddCircle(ArcEnd, RR)
    Cir.Color = 1
    With rst  '批量更新数据库
      !ArcHandleID = Trim(Ent.Handle)
      !ArcX0 = ArcStart(0)
      !ArcY0 = ArcStart(1)
      !ArcZ0 = ArcStart(2)
      !ArcX = ArcEnd(0)
      !ArcY = ArcEnd(1)
      !ArcZ = ArcEnd(2)
      .UpdateBatch
      .MoveNext
    End With
  Next
    Set Ent = obj_Doc.HandleToObject(Str_Handle(ii))
    LineStart = Ent.startPoint: LineEnd = Ent.endPoint
    Set Cir = obj_ModelSpace.AddCircle(LineStart, RR)
    Cir.Color = 4
    With rst
      !PipeLineX0 = LineStart(0)
      !PipeLineY0 = LineStart(1)
      !PipeLineZ0 = LineStart(2)
      !PipeLineX = LineEnd(0)
      !PipeLineY = LineEnd(1)
      !PipeLineZ = LineEnd(2)
    End With
  Next ii
  rst1.MoveNext
Loop
GMT+8, 2025-12-1 04:10 , Processed in 0.122660 second(s), 23 queries , Gzip On.
