查看: 1608|回复: 2
[求助]如何用vba建立一个有扭转角的view
发表于 2007-1-4 14:20:00 | 显示全部楼层 |阅读模式
在一般开启的图形档,X向右为正,Y向上为正,要取得现有视图做成VIEW可利用利用系统变数VIEWCTR取得视图中心,VIEWSIZE取得宽度,再利用SCREENSIZE来转换长度,用以建立VIEW.
但如果座标系还是WCS(世界座标),但图形已被旋转(X并不向右,Y并不向上),请问有人知道要如何用VBA来建立VIEW吗??
发表于 2007-1-5 08:32:00 | 显示全部楼层
关于视图方向
  1. Sub Example_Direction()    ' This example creates a circle in model space    ' and changes the thickness of the circle. Once    ' the thickness has been changed, the direction    ' of the active viewport is changed so that the    ' new thickness setting is visible.       Dim circleObj As AcadCircle    Dim centerPoint(0 To 2) As Double    Dim radius As Double        ' Define the circle    centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#    radius = 5#        ' Create the Circle object in model space    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)            ' Change the thickness of the circle    circleObj.Thickness = 3        ' Change the direction of the viewport so that you can    ' view the change made to the thickness. Once you change    ' the direction, you must reset the active viewport.    Dim NewDirection(0 To 2) As Double    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1    ThisDrawing.ActiveViewport.direction = NewDirection    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport    End Sub
 楼主| 发表于 2007-1-5 13:29:00 | 显示全部楼层
感谢版主的回答,但我说的是扭转,不是方向耶
扭转角可以由系统变数VIEWTWIST取得
但VIEW对象,也没有这项属性
真不知道要如何建立有扭转角的VIEW
还望版主多多指点
GMT+8, 2025-12-1 04:09 , Processed in 0.123582 second(s), 23 queries , Gzip On.
