查看: 1887|回复: 4
[求助]blockref 与 getboundingbox 的问题
发表于 2007-1-7 21:51:00 | 显示全部楼层 |阅读模式
代码如下:
Dim BlkRef As AcadBlockReference
Dim SelSet As AcadSelectionSet
Set SelSet = AcadDoc.SelectionSets.Add("SelSet1")
Dim aaa(0) As Integer   'Select 条件1:选择类型
Dim aaa1(0) As Variant  'select 条件2:选择图元
Dim maxPoint As Variant
Dim minPoint As Variant
aaa(0) = 0     '图元类型
aaa1(0) = "INSERT"    '图块
SelSet.Select acSelectionSetAll, , , aaa, aaa1       '选择所有图块
For Each BlkRef In SelSet
  Debug.Print BlkRef.Name
  BlkRef.GetBoundingBox minPoint, maxPoint
Next
这段程序用来得到所有块的BoundingBox的,但是,得到的minPoint和maxPoint 都是Empty。 怎么回事呢?
程序确确实实能够选择所有的块,而且名字也都是正常的,但是只要调用getboundingbox方法,要么为空,要么
就直接退出当前函数了,
请大侠们指教
发表于 2007-1-8 09:08:00 | 显示全部楼层
该程序正常的啊,不知你是否有SelSet.Delete语句
发表于 2007-1-8 10:21:00 | 显示全部楼层
在我这里可以得到的
  1. Dim BlkRef As AcadBlockReference
  2. Dim SelSet As AcadSelectionSet
  3. Set SelSet = ThisDrawing.SelectionSets.Add("SelSet1")
  4. Dim aaa(0) As Integer   'Select 条件1:选择类型
  5. Dim aaa1(0) As Variant  'select 条件2:选择图元
  6. Dim maxPoint As Variant
  7. Dim minPoint As Variant
  8. aaa(0) = 0     '图元类型
  9. aaa1(0) = "INSERT"    '图块
  10. SelSet.Select acSelectionSetAll, , , aaa, aaa1       '选择所有图块
  11. For Each BlkRef In SelSet
  12.   MsgBox BlkRef.Name
  13.   BlkRef.GetBoundingBox minPoint, maxPoint
  14. Next
  15. If Not SelSet Is Nothing Then SelSet.Delete
 楼主| 发表于 2007-1-8 16:52:00 | 显示全部楼层
我把我的图纸上传下,大侠们棒棒忙看下,谢谢
发表于 2007-1-8 17:09:00 | 显示全部楼层
对的啊
  1. Sub test()
  2. Dim BlkRef As AcadBlockReference
  3. Dim SelSet As AcadSelectionSet
  4. Set SelSet = ThisDrawing.SelectionSets.Add("SelSet0")
  5. Dim aaa(0) As Integer   'Select 条件1:选择类型
  6. Dim aaa1(0) As Variant  'select 条件2:选择图元
  7. Dim maxPoint As Variant
  8. Dim minPoint As Variant
  9. aaa(0) = 0     '图元类型
  10. aaa1(0) = "INSERT"    '图块
  11. SelSet.Select acSelectionSetAll, , , aaa, aaa1       '选择所有图块
  12. For Each BlkRef In SelSet
  14.    MsgBox maxPoint(0)
  15. Next
  16. SelSet.Delete
  17. End Sub
GMT+8, 2025-5-3 05:48 , Processed in 0.167835 second(s), 24 queries , Gzip On.
