查看: 2088|回复: 3
[Help] how to store and extract a LIST in an environment variable?
发表于 2003-4-9 11:14:00 | 显示全部楼层 |阅读模式
I have an list variable mixed with strings and real numbers
i.e. ("A" "B" 2.0 3.4 ...)
Now i want to store this list in an enviroment system varibles using
(setenv ...)
However, it can only store a string not a list...
if I transfer it into a string, it might be hard to extract the data when i need it...
Anybody get a better way to do this, please give me a hand.
发表于 2003-4-9 12:00:00 | 显示全部楼层
MAYBE....
指令: (SETENV "LAI" "(\"A\" \"B\" 2.0 3.4)" )
指令: (READ(GETENV "LAI"))
("A" "B" 2.0 3.4)
指令: (TYPE(READ(GETENV "LAI")))
LIST
发表于 2003-4-9 12:07:00 | 显示全部楼层
use your method,it's not hard.
use (vl-prin1-to-string...) transfer it to string, when you extract,after you extract a string "str",you can use (read str),you will get a list.
 楼主| 发表于 2003-4-10 21:40:00 | 显示全部楼层
thank you
GMT+8, 2025-4-5 23:34 , Processed in 0.176159 second(s), 27 queries , Gzip On.
