查看: 1720|回复: 3
[求助]关于选择集
发表于 2007-1-14 21:54:00 | 显示全部楼层 |阅读模式
我想一次选中图内所有图块但用下面的过滤不行:
            If acaddoc.SelectionSets.Count <> 0 Then
                For j = 0 To (acaddoc.SelectionSets.Count - 1)
                    Set Selset = acaddoc.SelectionSets.Item(j)
                    Selset.Delete
                Next j
            End If
            Set Selset = acaddoc.SelectionSets.Add("Sel1")
            Ftype(0) = 0: Fdata(0) = "AcDbBlockReference"
            Dim groupCode As Variant, dataCode As Variant
            groupCode = Ftype: dataCode = Fdata
            Selset.Select acSelectionSetAll, , , groupCode, dataCode
            a = Selset.Count
    块的名称应该为"AcDbBlockReference"还是"BLOCK REFERENCE"?或者是其它的?
下面代码就能选出图内的多段线.
                    Selset.Delete
                Next j
            End If
            Ftype(0) = 0: Fdata(0) = "LWPOLYLINE"
            a = Selset.Count
发表于 2007-1-15 08:44:00 | 显示全部楼层
块的名称应该为"insert"
 楼主| 发表于 2007-1-17 22:56:00 | 显示全部楼层
搞对了,非常感谢wyj7485
发表于 2007-5-4 20:59:00 | 显示全部楼层
好啊!
GMT+8, 2025-5-2 06:55 , Processed in 0.155744 second(s), 23 queries , Gzip On.
