查看: 1477|回复: 3
ssget 过滤的问题
发表于 2007-1-14 22:53:00 | 显示全部楼层 |阅读模式
如何同ssget 选取指定图层的点对象啊,下面这段代码错在那里啊
(setq deljmdd (ssget "x" '((-4 ."<AND") (0 . "point") (8 . "jmd")(-4 . "AND>"))))
发表于 2007-1-15 08:15:00 | 显示全部楼层
Command: (setq deljmdd (ssget "x" '((-4 ."<AND") (0 . "point") (8 . "jmd")(-4 . "AND>"))))
; error: misplaced dot on input
Command: (setq deljmdd (ssget "x" '((-4 . "<AND") (0 . "point") (8 . "jmd")(-4 . "AND>"))))
<Selection set: 5>
Command: (setq deljmdd (ssget "x" '((0 . "point") (8 . "jmd"))))
<Selection set: 7>
(-4 ."<AND")  ===> (-4 . "<AND")
点的左右皆要有空格
发表于 2007-1-15 17:00:00 | 显示全部楼层
(ssget "X" (list (cons 0 "OINT") (cons 8 "JMD")))就可以了,没那么复杂
发表于 2007-1-15 23:29:00 | 显示全部楼层
看看cad帮助,吃透说明
GMT+8, 2025-11-23 12:54 , Processed in 0.178270 second(s), 26 queries , Gzip On.
