查看: 1997|回复: 1
加载线形时失败[求助]
发表于 2003-4-9 12:55:00 | 显示全部楼层 |阅读模式
您好,我用以下方法加载线形时失败不知何故??
        ' 从acadiso.lin文件中加载线型“ACAD_ISO02W100”
        ThisDrawing.Linetypes.Load "ACAD_ISO02W100", "acadiso.lin"
        Set line = ThisDrawing.ModelSpace.AddLine(p1, p2)
        line.Linetype = "ACAD_ISO02W100"
        line.Update
我用的是acad2000
发表于 2003-4-9 21:50:00 | 显示全部楼层
按你的说法没有问题,注意线型不能重复加载,如重复加载会出错
Sub SetLineType()
    On Error Resume Next
    Dim LT As AcadLineType
    Set LT = ThisDrawing.Linetypes("ACAD_ISO02W100")
    If Err Then ThisDrawing.Linetypes.Load "ACAD_ISO02W101", "acadiso.lin"
    Dim p1(0 To 2) As Double
    Dim p2(0 To 2) As Double
    Dim line As AcadLine
    p1(0) = 0
    p1(1) = 0
    p1(2) = 0
    p2(0) = 100
    p2(1) = 100
    p2(2) = 0
    line.Update
End Sub
GMT+8, 2025-5-23 07:06 , Processed in 0.164603 second(s), 23 queries , Gzip On.
