查看: 2300|回复: 4
[求助]遍历块得到块中属性值的LIST
发表于 2007-1-17 21:18:00 | 显示全部楼层 |阅读模式
(DEFUN swp_get_attrib (en / f dxf)
  (WHILE en
    (SETQ dxf (ENTGET en))
    (IF (= (CDR (ASSOC 0 dxf)) "ATTRIB")
      (SETQ
 f (APPEND
     f
     (LIST
       (CDR (ASSOC 1 dxf))
    (SETQ en (ENTNEXT en))
  f
本来是想获取当前块(EN)中属性值的LIST的,结果出现了遍历图中自该图元后所有块的属性的错误,不知道怎么修改,请看看怎么改啊!
发表于 2007-1-18 08:36:00 | 显示全部楼层
(defun SWP_GET_ATTRIB (EN / F DXF)
  (setq DXF (entget EN))
  (if (and (= (DXF 0 EN) "INSERT")
    (assoc 66 DXF)
    (while (and (setq EN (entnext EN))
  (/= (cdr (assoc 0 DXF)) "SEQEND")
      (setq
 F (append
     F
     (list
       (cdr (assoc 1 DXF))
  F
 楼主| 发表于 2007-1-18 14:02:00 | 显示全部楼层
多谢龙版!
发表于 2007-1-18 14:21:00 | 显示全部楼层
  1. (defun c:tt()
  2. (setq blk (car(entsel)));;本行可根据需要修改
  3. (mapcar 'vla-get-textstring (vlax-invoke (vlax-ename->vla-object blk) 'GetAttributes));;本行为根据块实体名求属性值列表
  4. )
发表于 2013-11-16 19:41:22 | 显示全部楼层
稍加修改应该不错
GMT+8, 2025-7-19 02:59 , Processed in 0.153128 second(s), 26 queries , Gzip On.
