查看: 1718|回复: 4
[求助]VBA如何修改线宽?
发表于 2007-1-30 10:48:00 | 显示全部楼层 |阅读模式
请问在VBA中如何自定义线条宽度呀?
请大家多多帮助一下啊!
发表于 2007-1-30 12:34:00 | 显示全部楼层
说具体点。
发表于 2007-1-30 15:11:00 | 显示全部楼层
object.Lineweight
 楼主| 发表于 2007-1-31 17:05:00 | 显示全部楼层
总是提示不支持这个属性哦
发表于 2007-2-1 08:27:00 | 显示全部楼层
这里有个例子,帮助里面的,
Sub Example_LineWeight()
    ' This example creates a circle in model space and then
    ' finds the current lineweight for the circle. The lineweight
    ' is then changed to a new value.
    Dim circleObj As AcadCircle
    Dim centerPoint(0 To 2) As Double
    Dim radius As Double
    ' Define the circle
    centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    ZoomAll
    ' Find the lineweight for the circle
    MsgBox "The current lineweight for the circle is " & circleObj.Lineweight
    ' Change the lineweight for the circle
    circleObj.Lineweight = acLnWt211
    circleObj.Update
End Sub
GMT+8, 2025-5-2 12:20 , Processed in 0.173540 second(s), 23 queries , Gzip On.
