查看: 1256|回复: 1
是高手的进来,看来这个程序有什么问题!
发表于 2007-1-30 18:58:00 | 显示全部楼层 |阅读模式
我想生成一个10行的表格,表格中的列我想我想能够写,能够读,所以选择了属性块,但是我在插入属性块时,属性块不能在表格的行的中央!我看不出程序有什么问题,请高手帮帮忙!下面是程序代码!
//在块中插入属性
procedure addattr(ptinsert:variant;b2: AcadBlock;attriname:string;attrtext:string;p:real;height:real; heightrec:real);
var
temp:variant;
begin
temp:=varArrayCreate([0,2],varDouble);
temp[0]:=0; temp[1]:=0; temp[2]:=0;
temp[0]:=ptinsert[0]+p;temp[1]:=ptinsert[1]+heightrec/2; temp[2]:=ptinsert[2];
b2.AddAttribute(height,0,attriname,temp,attriname,attrtext);
end;
//插入10行带属性的数据
procedure TForm1.Button15Click(Sender: TObject);
var
a:integer;
b:integer;
c:integer;
d:integer;
e:integer;
f:integer;
g:integer;
h:integer;
i:integer;
p1,p2,p3,p4:olevariant; //块里面的直线点
p5,p6,p7,p8:olevariant;//插入点
p9:olevariant;
p10:olevariant;
p11:olevariant;
p12:olevariant;
p13:olevariant;
p14:olevariant;
p15:olevariant;
p16:olevariant;
p17:olevariant;
p18:olevariant;
m:integer;//循环步长
series:string;
kkscode:string;
reserve:string;
cablestart:string;
cableend:string;
cabletype:string;
remarks:string;
begin
a:=10;
b:=55;
c:=25;
d:=70;
e:=70;
f:=55;
g:=22;
h:=45;
i:=9;
p1:=vararraycreate([0,2],varDouble);//一定要先创建
p2:=vararraycreate([0,2],varDouble);
p3:=vararraycreate([0,2],varDouble);
p4:=vararraycreate([0,2],varDouble);
p5:=vararraycreate([0,2],varDouble);
p6:=vararraycreate([0,2],varDouble);
p7:=vararraycreate([0,2],varDouble);
p8:=vararraycreate([0,2],varDouble);
p9:=vararraycreate([0,2],varDouble);
p10:=vararraycreate([0,2],varDouble);
p11:=vararraycreate([0,2],varDouble);
p12:=vararraycreate([0,2],varDouble);
p13:=vararraycreate([0,2],varDouble);
p14:=vararraycreate([0,2],varDouble);
p15:=vararraycreate([0,2],varDouble);
p16:=vararraycreate([0,2],varDouble);
p17:=vararraycreate([0,2],varDouble);
p18:=vararraycreate([0,2],varDouble);
ml:=acad.ActiveDocument.ModelSpace;
p1[0]:=0;       p1[1]:=0; p1[2]:=0;//基准点,以后要能交互选择
for m:=0 to 10 do
begin
p10[0]:=p1[0];   p10[1]:=p1[1]-i;     p10[2]:=0;
p2[0]:=p1[0]+a; p2[1]:=p1[1];      p2[2]:=0;
p11[0]:=p2[0];   p11[1]:=p2[1]-i;     p11[2]:=0;
p3[0]:=p2[0]+b; p3[1]:=p2[1];      p3[2]:=0;
p12[0]:=p3[0];   p12[1]:=p3[1]-i;     p12[2]:=0;
p4[0]:=p3[0]+c; p4[1]:=p3[1];      p4[2]:=0;
p13[0]:=p4[0];   p13[1]:=p4[1]-i;     p13[2]:=0;
p5[0]:=p4[0]+d; p5[1]:=p4[1];      p5[2]:=0;
p14[0]:=p5[0];   p14[1]:=p5[1]-i;     p14[2]:=0;
p6[0]:=p5[0]+e; p6[1]:=p5[1];      p6[2]:=0;
p15[0]:=p6[0];   p15[1]:=p6[1]-i;     p15[2]:=0;
p7[0]:=p6[0]+f; p7[1]:=p6[1];      p7[2]:=0;
p16[0]:=p7[0];   p16[1]:=p7[1]-i;     p16[2]:=0;
p8[0]:=p7[0]+g; p8[1]:=p7[1];      p8[2]:=0;
p17[0]:=p8[0];   p17[1]:=p8[1]-i;     p17[2]:=0;
p9[0]:=p8[0]+h; p9[1]:=p8[1];      p9[2]:=0;
p18[0]:=p9[0];   p18[1]:=p9[1]-i;     p18[2]:=0;
bl:=acad.ActiveDocument.Blocks.Add(p1,inttostr(m));
bl.addline(vararrayref(p1), vararrayref(p2));
bl.addline(vararrayref(p2), vararrayref(p3));
bl.addline(vararrayref(p3), vararrayref(p4));
bl.addline(vararrayref(p4), vararrayref(p5));
bl.addline(vararrayref(p5), vararrayref(p6));
bl.addline(vararrayref(p6), vararrayref(p7));
bl.addline(vararrayref(p7), vararrayref(p8));
bl.addline(vararrayref(p8), vararrayref(p9));
bl.addline(vararrayref(p10), vararrayref(p11));
bl.addline(vararrayref(p11), vararrayref(p12));
bl.addline(vararrayref(p12), vararrayref(p13));
bl.addline(vararrayref(p13), vararrayref(p14));
bl.addline(vararrayref(p14), vararrayref(p15));
bl.addline(vararrayref(p15), vararrayref(p16));
bl.addline(vararrayref(p16), vararrayref(p17));
bl.addline(vararrayref(p17), vararrayref(p18));
bl.addline(vararrayref(p1), vararrayref(p10));
bl.addline(vararrayref(p2), vararrayref(p11));
bl.addline(vararrayref(p3), vararrayref(p12));
bl.addline(vararrayref(p4), vararrayref(p13));
bl.addline(vararrayref(p5), vararrayref(p14));
bl.addline(vararrayref(p6), vararrayref(p15));
bl.addline(vararrayref(p7), vararrayref(p16));
bl.addline(vararrayref(p8), vararrayref(p17));
bl.addline(vararrayref(p9), vararrayref(p18));
 addattr(p10,bl,'series','series',1,3,9);
 addattr(p11,bl,'name','name',1,3,9);
 addattr(p12,bl,'kkscode','kkscode',1,3,9);
 addattr(p13,bl,'reservecore','reservecore',1,3,9);
 addattr(p14,bl,'cablestart','cablestart',1,3,9);
 addattr(p15,bl,'cablesend','cablesend',1,3,9);
 addattr(p16,bl,'cabletype','cabletype',1,3,9);
 addattr(p17,bl,'remarks','remarks',1,3,9);
acad.ActiveDocument.ModelSpace.InsertBlock(p1,bl.name,1,1,1,0,0);
p1[0]:=0;       p1[1]:=0-m*i;           p1[2]:=0;//基准点,以后要能交互选择
end;
发表于 2007-2-6 13:05:00 | 显示全部楼层
你用的不是2005以上的版本?直接调用表格对象好了。
GMT+8, 2025-3-11 15:44 , Processed in 0.194471 second(s), 24 queries , Gzip On.
