查看: 1631|回复: 2
[求助]CAD内可否将文字编成块(块要求不能再进行Copy,Delete等任何操作)
发表于 2007-2-1 14:23:00 | 显示全部楼层 |阅读模式
  CAD内可否将文字编成块(块要求不能再进行Copy,Delete.炸开,move等任何操作),就像一个签名,
发表于 2007-2-1 18:09:00 | 显示全部楼层
完全可以,在mjtd讲的比较细,找一下吧.
主要示例
Sub Example_InsertBlock()
    ' This example creates a block containing a circle.
    ' It then inserts the block.
    ' Create the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
    ' Add a circle to the block
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 0: center(1) = 0: center(2) = 0
    radius = 1
    Set circleObj = blockObj.AddCircle(center, radius)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
    ZoomAll
End Sub
 楼主| 发表于 2007-2-6 13:44:00 | 显示全部楼层
找了好几天那位大哥可否发个链上来,
  THANKS A LOT!!!
GMT+8, 2025-5-2 12:14 , Processed in 0.167621 second(s), 23 queries , Gzip On.
