查看: 1393|回复: 0
帮解决下问题,不甚感激
发表于 2007-2-2 08:56:00 | 显示全部楼层 |阅读模式
程序的目的是希望分解每个图元后,将其再重新还原到原层
问题一:我想调用最下边这个explodere是否正确
问题二;和昨天问的一样,怎么解决图元分解为题(不是块)element.explode不行用什么其他的方法正确
刚开始学vb,用vba做东ix,这个是我写的程序,有很多问题,希望高手解决下,不甚感激
Private Sub explode()
On Error Resume Next
Dim sset As AcadSelectionSet
If Not IsNull(ThisDrawing.SelectionSets.Item("all")) Then
   Set sset = ThisDrawing.SelectionSets.Item("all")
   sset.Delete
End If
Set sset = ThisDrawing.SelectionSets.Add("all")
Dim filtertype(0 To 8) As Integer
Dim filterdata(0 To 8) As Variant
filtertype(0) = 8: filterdata(0) = "AERTAL"
filtertype(1) = 8: filterdata(1) = "BURIED"
filtertype(2) = 8: filterdata(2) = "HICAP"
filtertype(3) = 8: filterdata(3) = "KANDBASE"
filtertype(4) = 8: filterdata(4) = "NOTE"
filtertype(5) = 8: filterdata(5) = "SYSTEM"
filtertype(6) = 8: filterdata(6) = "TELCO_BOUNDARY"
filtertype(7) = 8: filterdata(7) = "TERMINAL"
filtertype(8) = 8: filterdata(8) = "BORDERSTAMP"
sset.Select acSelectionSetAll, , , filtertype, filterdata
Dim element As AcadEntity
Dim layername As Variant
For Each element In sset
    layername = element.Layer
    Select Case layername
       Case "AERTAL"
       Call explodere(element)
       Case "BURIED"
       Case "HICAP"
       Case "KANDBASE"
       Case "NOTE"
       Case "SYSTEM"
       Case "TELCO_BOUNDARY"
       Case "TERMINAL"
       Case "BORDERSTAMP"
    End Select
Next
sset.Delete
End Sub
//希望分步执行的时候调用他
Private Sub explodere(element)
'分解该元素
element.explode
'将层反回
element.Layer = layername
End Sub
GMT+8, 2025-7-6 12:06 , Processed in 0.172386 second(s), 23 queries , Gzip On.
