查看: 2233|回复: 7
[求助]手上有个被加密的VBA文件那位大哥可否帮忙解开
发表于 2007-2-6 13:55:00 | 显示全部楼层 |阅读模式
我用Office Key or Advanced VBA Password Recovery PRO or VBA Password Bypasser这三个都解不开,这是一家台湾公司写的读取硬盘序列号的小程序
发表于 2007-2-6 14:52:00 | 显示全部楼层
Declare Function GetVolumeinformation Lib "Kernel32.dll" Alias "GetVolumeInformationA" (ByVal _
     lpRootPathName As String, ByVal lpVolumeNameBuffer As _
     String, ByVal nVolumeNameSize As Integer, _
     lpVolumeSerialNumber As Long, lpMaximumComponentLength _
     As Long, lpFileSystemFlags As Long, ByVal _
     lpFileSystemNameBuffer As String, ByVal _
     nFileSystemNameSize As Long) As Long
     Function GetSerialNumber(strDrive As String) As Long
     Dim SerialNum As Long
     Dim Res As Long
     Dim Temp1 As String
     Dim Temp2 As String
     Temp1 = String$(255, Chr$(0))
     Temp2 = String$(255, Chr$(0))
     Res = GetVolumeinformation(strDrive, Temp1, _
     Len(Temp1), SerialNum, 0, 0, Temp2, Len(Temp2))
     GetSerialNumber = SerialNum
     End Function
     Sub GetNum()
     Dim DNum As String
       DNum = GetSerialNumber("C:\")
       ThisDrawing.SetVariable "USERS1", DNum
     End Sub
 楼主| 发表于 2007-2-6 16:10:00 | 显示全部楼层
大哥你能给我密码吗?I服了YOU OR THANK YOU
 楼主| 发表于 2007-2-6 16:56:00 | 显示全部楼层
下面有一个是VB写的获取硬盘序列号的代码:
Private Declare Function GetVolumeInformation Lib "kernel32.dll" Alias _
    "GetVolumeInformationA" (ByVal lpRootPathName As String, _
    ByVal lpVolumeNameBuffer As String, ByVal nVolumeNameSize As Integer, _
    lpVolumeSerialNumber As Long, lpMaximumComponentLength As Long, _
    lpFileSystemFlags As Long, ByVal lpFileSystemNameBuffer As String, _
    ByVal nFileSystemNameSize As Long) As Long
Private Sub Command1_Click()
  Dim mySerial As Long
  Dim mylong As Long
  mystr = String$(255, Chr$(0))
  mytype = String$(255, Chr$(0))
  If Right(Text1.Text, 1) <> "\" Then Text1.Text = Text1.Text & "\"
  sRoot = Text1.Text                                   '设定盘名
  mylong = GetVolumeInformation(sRoot, mystr, Len(mystr), mySerial, 0, 0, mytype, Len(mytype))
  Text2.Text = mySerial                                'TEXT2 存放盘序列号
End Sub
Private Sub Command3_Click()
  End
End Sub
发表于 2007-2-6 17:00:00 | 显示全部楼层
是一样的
发表于 2007-2-7 09:10:00 | 显示全部楼层
这个论坛就有。自己搜下我的贴子。
发表于 2007-2-13 09:22:00 | 显示全部楼层
没看明白
发表于 2007-3-13 01:09:00 | 显示全部楼层
     Dim Res As Long
     Dim Temp1 As String
     Dim Temp2 As String
     End Function
     Sub GetNum()
     Dim DNum As String
     End Sub
H××兄更胜一筹
GMT+8, 2025-5-2 07:06 , Processed in 0.261714 second(s), 30 queries , Gzip On.
