- 积分
- 653
- 明经币
- 个
- 注册时间
- 2002-10-11
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
请问龙大侠,怎么修改才能将这个循环选择程序返回的点表每个子表内的坐标值全部改成小数点后只含3位有效数字的小数呢?如某一坐标值为20。0 该为20。000 如为-2.13163e-014,则能将它近似为0。000 如果是整型的,也一并改成**.***的形式。
(defun C:TT (/ SS SS1 N N1 NN ENT CHECK TMP PT_LIST)
(defun DO_IT (TMP)
(if
(and
(not (equal (car TMP) (cadr TMP)))
(= (vl-position TMP PT_LIST) NIL)
(= (vl-position (list (cadr TMP) (car TMP)) PT_LIST) NIL)
(setq PT_LIST (append PT_LIST (list TMP)))
(defun DO_IT1 (ENT / TMP)
(setq TMP (list (cdr (assoc 10 ENT))
(cdr (assoc 11 ENT))
(DO_IT TMP)
(setq SS (ssget '((0 . "polyline,line,lwpolyline,3dface,region"))))
(setq PT_LIST '())
(setq N 0)
(repeat (sslength SS)
(setq ENT (ssname SS N))
(setq CHECK (cdr (assoc 100 (reverse (entget ENT)))))
(cond
((or (= CHECK "AcDbPolygonMesh") (= CHECK "AcDbFace"))
(if (= CHECK "AcDbPolygonMesh")
(command "_.COPY" ENT "" "0,0" "@")
(command "_.EXPLODE" (entlast))
(setq SS1 (ssget " "))
(progn (setq SS1 (ssadd)) (ssadd ENT SS1))
(setq N1 0)
(repeat (sslength SS1)
(setq ENT (entget (ssname SS1 N1)))
(setq NN 0)
(setq LINE0 (list (cdr (assoc 10 ENT))
LINE1 (list (cdr (assoc 11 ENT))
(cdr (assoc 12 ENT))
LINE2 (list (cdr (assoc 12 ENT))
(cdr (assoc 13 ENT))
LINE3 (list (cdr (assoc 13 ENT))
(repeat 4
(setq TMP (eval (read (strcat "LINE" (rtos NN)))))
(DO_IT TMP)
(setq NN (1+ NN))
(setq N1 (1+ N1))
(command "_.ERASE" SS1 "")
((or (= CHECK "AcDb3dPolyline")
(= CHECK "AcDb2dPolyline")
(= CHECK "AcDbPolyline")
(= CHECK "AcDbModelerGeometry")
(setq N1 0)
(setq ENT (ssname SS1 N1))
(DO_IT1 (entget ENT))
(setq N1 (1+ N1))
(t
(setq N (1+ N))
(princ "\n")
