会不会是这个? Specifies the tab order of a layout. MSITStore:C:\AutoCAD2006\help\acadauto.chm::/taborder_see_also.htm">See Also | MSITStore:C:\AutoCAD2006\help\acadauto.chm::/ex_taborder.htm">Example Signature object.TabOrder object MSITStore:C:\AutoCAD2006\help\acadauto.chm::/idh_layout_object.htm">Layout The object or objects this property applies to. TabOrder Long; read-write The tab order for the layout. Remarks This property controls the order in which the layouts are displayed in the tab control. The tab order should be unique and sequential among all layouts in the database. The model space tab must have a tab order of zero (0). Paper space tabs must have a tab order of 1 or greater. |
