查看: 1383|回复: 6
After rotate UCS
发表于 2007-2-21 11:34:00 | 显示全部楼层 |阅读模式
I use the following commands:
UCS
Z
60
to rotate the coordinate about Z axis for 60 degree..
After that, How could I get the number I rotated?
I have a drawing of which the ucs is not at the origin. There is an angle. I want to get the angle and rotate it back to normal position.
Thanks.
发表于 2007-2-21 16:14:00 | 显示全部楼层
UCS→p    Rotate back the UCS angle
UCS→n→indicate the origin position you want
 楼主| 发表于 2007-2-21 18:14:00 | 显示全部楼层
我主要关心的是角度。
比如原图坐标系相对于普通的直角坐标系旋转了42.732度。我打开这个图后怎样得到这个角度值,以便转回到直的坐标。
发表于 2007-2-22 09:01:00 | 显示全部楼层
請參考:
 楼主| 发表于 2007-2-22 18:33:00 | 显示全部楼层
没明白。
转了后画两条线相互垂直的线。用list看什么呀?根据什么转回来?
发表于 2007-2-23 08:58:00 | 显示全部楼层
Angle in X Y plane→UCS rotate angle
 楼主| 发表于 2007-2-24 12:10:00 | 显示全部楼层
没太大帮助。
在倾斜的坐标系下任意画条线不行。打开正交再画,list后角度是0或者90。只能根据坐标自己计算了。
GMT+8, 2025-5-7 07:52 , Processed in 0.186704 second(s), 26 queries , Gzip On.
