Stores LISP data in a drawing dictionary or an object (vlax-ldata-put dict
key
data [private]) Arguments dict
A VLA-object, AutoCAD drawing entity object, or a string naming a global dictionary. key
A string specifying the dictionary key. data
LISP data to be stored in
the dictionary. private
If vlaxldataput is called from a separate-namespace VLX and a non-nil value is specified for private, vlaxldataput marks the data as retrievable only by the same VLX. Return Values The value of data. Examples _$ (vlax-ldata-put "dict" "key" '(1)) (1) _$ (vlax-ldata-put "dict" "cay" "Gumbo jumbo") "Gumbo jumbo" |
