;林树才 设计 ;此程序版权没有,可以有意无意地进行复制与散布,不过请务将此信息删除 (defun learnword( / f m n) (setq n 1) ;(setq f (getfiled "选择要阅读的文件" "" "txt" 8)) ;文件所在目录一定要为支持搜索 (setq f (open (findfile (getfiled "选择要阅读的文件" "" "txt" 8)) "r")) (initget 1 ) (setq m (getint "\n按Esc退出,可输入[1~8]数值越大则越快:->")) (setvar "cmdecho" 0) (while n (princ (strcat "\n" (read-line f))) (command "delay" (itoa (fix (/ 8000 m )))) ; (setq n (getint)) ; (if (= n 1) ; (princ "继续") ; (setq n 0) ; ) ) (close f) (setvar "cmdecho" 1) ) (learnword) 总算改得像样了,(setq f (open (findfile (getfiled "选择要阅读的文件" "" "txt" 8)) "r")) 这句修改了一下.祝各位工作,学习快乐. |
