请参考以下代码 ;;;尺寸工具 ;;;Copyrignt chengqiang Lin 2007 for yuksang (defun c:sd () (setvar "cmdecho" 0) (prompt "\n请选择尺寸:") (setq ss (ssget '((0 . "DIMENSION"))) n 0 ) (setq pc1 (getstring "\n输入上偏差:")) (setq pc3 (getstring "\n输入下偏差:")) (setq pc_a_1 (atof pc1)) (setq pc_a_2 (atof pc3)) (setq pc_a_3 (+ pc_a_1 pc_a_2)) (if (= pc_a_3 0.0) (progn (setq t0 "%%p") (setq t3 pc_a_1) (setq t3 (rtos t3)) (setq nam (strcat t0 t3 )) ) (princ) ) (if (/= pc_a_3 0.0) (progn (setq t0 "\\A1;") (setq t1 "<>") (setq t2 "{\\H0.7x;\\S") (setq t3 pc1) (setq t4 "^") (setq t5 pc3) (setq t6 ";}") (setq nam (strcat t0 t1 t2 t3 t4 t5 t6)) ) (princ) ) (repeat (sslength ss) (setq entlst (entget (ssname ss n)) n (1+ n) olddxf (cdr (assoc 1 entlst)) ) (if (= olddxf "") (setq newdxf (cons 1 (strcat olddxf nam)) ) ) (setq entlst (subst newdxf (assoc 1 entlst) entlst)) (entmod entlst) ) (princ) ) (defun c:as () (setvar "cmdecho" 0) (prompt "\n请选择尺寸:") (setq ss (ssget '((0 . "DIMENSION"))) n 0 ) (setq nam "%%C<>") (repeat (sslength ss) (setq entlst (entget (ssname ss n)) n (1+ n) olddxf (cdr (assoc 1 entlst)) ) (if (= olddxf "") (setq newdxf (cons 1 (strcat olddxf nam)) ) ) (setq entlst (subst newdxf (assoc 1 entlst) entlst)) (entmod entlst) ) (princ) ) (defun c:aq () (setvar "cmdecho" 0) (prompt "\n请选择尺寸:") (setq ss (ssget '((0 . "DIMENSION"))) n 0 ) (setq nam "%%p<>") (repeat (sslength ss) (setq entlst (entget (ssname ss n)) n (1+ n) olddxf (cdr (assoc 1 entlst)) ) (if (= olddxf "") (setq newdxf (cons 1 (strcat olddxf nam)) ) ) (setq entlst (subst newdxf (assoc 1 entlst) entlst)) (entmod entlst) ) (princ) ) (defun c:aw () (setvar "cmdecho" 0) (prompt "\n请选择尺寸:") (setq ss (ssget '((0 . "DIMENSION"))) n 0 ) (setq nam "<>%%d") (repeat (sslength ss) (setq entlst (entget (ssname ss n)) n (1+ n) olddxf (cdr (assoc 1 entlst)) ) (if (= olddxf "") (setq newdxf (cons 1 (strcat olddxf nam)) ) ) (setq entlst (subst newdxf (assoc 1 entlst) entlst)) (entmod entlst) ) (princ) ) |
