- 积分
- 3657
- 明经币
- 个
- 注册时间
- 2004-1-8
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2007-3-12 09:49:00
显示全部楼层
<pre class="Code">Sub Example_Rotate()
' This example creates a lightweight polyline
' and then rotates that polyline.
' Create the polyline
Dim plineObj As AcadLWPolyline
Dim points(0 To 11) As Double
points(0) = 1: points(1) = 2
points(2) = 1: points(3) = 3
points(4) = 2: points(5) = 3
points(6) = 3: points(7) = 3
points(8) = 4: points(9) = 4
points(10) = 4: points(11) = 2
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
plineObj.Closed = True
ZoomAll
MsgBox "Rotate the polyline by 45 degrees.", , "Rotate 示例"
' Define the rotation
Dim basePoint(0 To 2) As Double
Dim rotationAngle As Double
basePoint(0) = 4: basePoint(1) = 4.25: basePoint(2) = 0
rotationAngle = 0.7853981 ' 45 degrees
' Rotate the polyline
plineObj.Rotate basePoint, rotationAngle
ZoomAll
MsgBox "Rotation completed.", , "Rotate 示例"
End Sub</pre> |
