查看: 2668|回复: 1
The function acedInvoke can not work
发表于 2007-3-13 16:34:00 | 显示全部楼层 |阅读模式
I defined myfun as following in lisp:
(defun myfun() (* 2 180))
And the function works right in command state.
commandmyfun)
360
But when I spawn the function in ARX,it's can not work.
Here is my code:
struct resbuf *result = NULL, *list;
list = acutBuildList(RTSTR, "myfun", 0);
if (list != NULL)
int stat = acedInvoke(list, &result);
if (stat == RTERROR)
acdbFail(L"Cannot run \n");
acutRelRb(list);
if (result != NULL)
// Do somthing
acutRelRb(result);
else
AfxMessageBox(L"NULL");
The result show "Cannot run " and result == NULL.
Please help me.
发表于 2010-8-23 19:31:00 | 显示全部楼层
改为list = acutBuildList(RTSTR, _T("myfun"), 0);
即可
GMT+8, 2025-5-26 01:39 , Processed in 0.174291 second(s), 23 queries , Gzip On.
