查看: 3556|回复: 1
[请教]如何通过图形句柄选择并缩放到图形呀
发表于 2007-3-19 12:02:00 | 显示全部楼层 |阅读模式
用vba很简单
Public Sub FindHandle()
    Dim ent As AcadEntity
    Dim returnObj As AcadObject
    Dim returnStr As String
    Dim MinP As Variant, MaxP As Variant
    On Error GoTo lblerr
    returnStr = ThisDrawing.Utility.GetString(False, "输入实体句柄:")
    Set returnObj = ThisDrawing.HandleToObject(returnStr)
    Set ent = returnObj
    ent.Highlight True
    ent.GetBoundingBox MinP, MaxP
    ZoomWindow MinP, MaxP
lblerr:
End Sub
但是现在需要用c#,我找不到合适的函数,现在只做到了选择元素(自己觉得效率很低),但是不知道怎么平移缩放到该元素:
Database db = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
   Transaction trans = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction();
   try
    long l = long.Parse(textBox_Element_Handle.Text, System.Globalization.NumberStyles.HexNumber);
    romptSelectionResult prSelectionRes = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.SelectAll();
    if (prSelectionRes.Status != PromptStatus.OK)
     throw new System.Exception("未找到图形元素!");
    ObjectId[] ois = prSelectionRes.Value.GetObjectIds();
    foreach (ObjectId objId in ois)
     Entity en = (Entity)trans.GetObject(objId, OpenMode.ForRead);
     if(en.Handle.Value == l)
      /*平移缩放到该元素*/
      /*知道的帮忙啊*/
      en.Highlight(new FullSubentityPath(new ObjectId[]{en.ObjectId}, new SubentityId(SubentityType.Null,0)),true);
      return;
    MessageBox.Show(@"未找到该句柄对应的图形元素!");
   catch (System.Exception Ex)
    MessageBox.Show(Ex.Message, @"错误");
   finally
    trans.Dispose();
请问有谁可以帮助我呢,或者有更简单的办法:)
发表于 2009-3-23 10:49:00 | 显示全部楼层
受教了!!!
GMT+8, 2025-11-26 15:09 , Processed in 0.170070 second(s), 30 queries , Gzip On.
