查看: 5708|回复: 11
56216349网友请进
发表于 2007-3-25 11:22:00 | 显示全部楼层 |阅读模式
  1. ;;这样似乎更好用一些
  2. ;;TRIM 和 EXTEND 命令(用于cad 2004版,仿照2006的矩形选框)
  3. ;;根据 AutoCAD 版本判断是否加载
  4. ;(if (< (atof (substr (getvar "acadver") 1 4)) 16.2)
  5. ; (progn
  6. ;;--------------------------------------------------
  7. (defun trim&extend (cmd / error error_end olderr ssget-g ssRedraw cm os ss1 ss2 lst)
  8.   (if cmd
  9.     (setq cmd "_.trim")
  10.     (setq cmd "_.extend")
  11.   )
  12.   (defun error (x) (error_end))
  13.   (defun error_end ()
  14.     (if ss1 (ss-Redraw ss1 4))
  15.     (if cm (setvar "cmdecho" cm))
  16.     (if os (setvar "osmode" os))
  17.     (setq *error* olderr)
  18.   )
  19.   (setq olderr *error* *error* error)
  20.   (defun ss-Redraw (ss mode)
  21.     (mapcar '(lambda (x) (redraw x mode))
  22.             (vl-remove-if-not '(lambda (x) (= (type x) 'ename)) (mapcar 'cadr (ssnamex ss)))
  23.     )
  24.   )
  25.   (setq cm (getvar "cmdecho")
  26.         os (getvar "osmode")
  27.   )
  28.   (setvar "cmdecho" 0)
  29.   (setvar "osmode" 0)
  30.   (defun ssget-g (msg fit / p1 p2 ss)
  31.     (if (not msg) (setq msg "\n选择对象: "))
  32.     (setq p1 (getpoint msg))
  33.     (if p1
  34.       (progn
  35.         (setq p2 (getcorner p1 "指定对角点: "))
  36.         (while (not p2)
  37.           (if (not p2) (princ "窗口说明无效。"))
  38.           (setq p2 (getcorner p1 (strcat msg "指定对角点: ")))
  39.         )
  40.         (setq ss (ssget "_c" p1 p2 fit))
  41.       )
  42.     )
  43.     (list ss p1 p2)
  44.   )
  45.   (princ "\n选择剪切边或 <全部选择>... ")
  46.   (setq ss1 (ssget))
  47.   (while
  48.     (progn
  49.       (if ss1 (ss-redraw ss1 3))
  50.       (apply 'or (setq lst (cdr (setq ss2 (ssget-g "\n选择要修剪的对象: " nil)))))
  51.     )
  52.     (if (car ss2)
  53.       (progn
  54.         (setq lst (list (car lst)
  55.                         (cons (caar lst) (cdadr lst))
  56.                         (cadr lst)
  57.                         (cons (caadr lst) (cdar lst))
  58.                         (car lst)
  59.                   )
  60.         )
  61.         (command cmd)
  62.         (if ss1 (command ss1 "") (command ""))
  63.         (command "_f")
  64.         (apply 'command lst)
  65.         (command "" "")
  66.       )
  67.     )
  68.   )
  69.   (error_end)
  70.   (princ)
  71. )
  72. (defun c:tr () (trim&extend T))
  73. (defun c:ex () (trim&extend nil))
  74. ;;--------------------------------------------------
  75. ; )
  76.   (princ)
  77. ;)
发表于 2007-3-27 18:49:00 | 显示全部楼层
谢谢。
好用
发表于 2007-3-27 19:02:00 | 显示全部楼层
我现在在学VB,
不知老兄对这可有研究?
向你学习啊!
感谢你的热心帮助!
 楼主| 发表于 2007-3-28 13:27:00 | 显示全部楼层
不懂VB啊,我向你学习!!
发表于 2007-3-28 14:28:00 | 显示全部楼层
我也是刚开始学,
感觉自己不能老是玩啊,也该趁年轻多学点东西。
所以就学了,VB上手快点,LISP感觉很难,望而却步啊
也没甚么老师,就自己瞎摸索。还好网上有不少教程啊
发表于 2007-6-25 14:47:00 | 显示全部楼层
个个都那么历害..向你们学习..
楼主辛苦你了...多谢啊....
发表于 2007-7-28 13:21:00 | 显示全部楼层
强烈感激!!!!!!
发表于 2007-7-28 13:38:00 | 显示全部楼层
再次强烈感激ID为caoyin  的网友 !真的是好人! 有热心的呀! 我找这个插件已经好几个月了!一直都没人知道或者说没人理会! 最后也只自己编了个栏选的插件! 今天终于遇见好人了! 十分感激哦! 这个论坛有你这样的德才兼备的人真是福气呀!
                                           敬礼ING
发表于 2007-7-28 13:54:00 | 显示全部楼层
忍不住1回来再感激一下! 真的是相当的好用!! 德才兼备的人才
发表于 2007-9-14 11:38:00 | 显示全部楼层
<p>发现此程序一个BUG ,执行命令后经常会把对象捕捉的设置清除! 很苦恼!总是反复的重新设置对象捕捉!希望作者能给解决下这个问题!一般是在矩形选框太小时候就会把对象捕捉清除! 另外可否象CAD2006一样点中曲线,单点剪切;点于空位就是矩形选框!&nbsp; 希望作者能再改进下!</p>
GMT+8, 2025-9-23 06:38 , Processed in 0.179013 second(s), 28 queries , Gzip On.
