DCL语句如下: dia9c:dialog{ label="专家出手:滑动条辅助[参数设计]"; :row{ spacer_1; :boxed_column{ label="二阶楼梯设计"; :image_button{key="kimage"; color=-2; width=30; aspect_ratio=1; allow_accept=true; } :slider{ key="slider_ww"; min_value=10; max_value=100; width=30; height=1; small_increment=5; big_increment=10; value="50"; } } :slider{ key="slider_hh"; min_value=10; max_value=100; width=1; height=30; small_increment=5; big_increment=10; layout=vertical; value="50"; } } :boxed_row{ label="参数设计相关尺寸"; :concatenation{ :text_part{label="宽度=[";} :text_part{key="kww";width=4;} :text_part{label="]";} } :concatenation{ :text_part{label="高度=[";} :text_part{key="khh";width=4;} :text_part{label="]";} } } spacer_1; ok_cancel; } 其驱动LISP语句如下: (defun c:dia9c() (setvar "cmdecho" 0) (setq old_osmode (getvar "osmode")) (setvar "osmode" 0) (dcl_dia9c) (setvar "osmode" old_osmode) (prin1) ) (defun dcl_dia9c() (setq dcl_id (load_dialog "dia9c")) (new_dialog "dia9c" dcl_id) (def_dia9c) (action_tile "slider_ww" "(sub_s_ww $value)") (action_tile "slider_hh" "(sub_s_hh $value)") (action_tile "accept" "(ok_dia9c) (done_dialog 1)") (setq dd (start_dialog)) (if (= dd 1) (draw_dia9c)) ) (defun def_dia9c() (setq wws "50" hhs "50") (set_tile "slider_ww" wws) (set_tile "slider_hh" hhs) (set_tile "kww" wws) (set_tile "khh" hhs) (dia9c_image) ) (defun sub_s_ww(vvs) (setq wws vvs) (set_tile "kww" wws) (dia9c_image) ) (defun sub_s_hh(vvs) (setq hhs vvs) (set_tile "khh" hhs) (dia9c_image) ) (defun dia9c_image() (setq key "kimage") (setq rx (dimx_tile key)) (setq ry (dimy_tile key)) (setq delta_x(/ rx 100)) (setq delta_y(/ ry 100)) (setq half_ww(/ (* delta_x (atoi wws)) 2)) (setq half_hh(/ (* delta_y (atoi hhs)) 2)) (setq p5x (/ rx 2)) (setq p5y (/ ry 2)) (setq p6x (- p5x half_ww)) (setq p6y p5y) (setq p1x p6x) (setq p1y (+ p5y half_hh)) (setq p2x (+ p5x half_ww)) (setq p2y (+ p5y half_hh)) (setq p4x p5x) (setq p4y (- p5y half_hh)) (setq p3x p2x) (setq p3y (- p5y half_hh)) (start_image key) (fill_image 0 0 x y -2) (vector_image p1x p1y p2x p2y 7) (vector_image p2x p2y p3x p3y 7) (vector_image p3x p3y p4x p4y 7) (vector_image p4x p4y p5x p5y 7) (vector_image p5x p5y p6x p6y 7) (vector_image p6x p6y p1x p1y 7) (end_image) ) (defun ok_dia9c() (setq ww (atof (get_tile "kww"))) (setq hh (atof (get_tile "khh"))) ) (defun draw_dia9c() (command "-layer" "m" "STR" "c" 1 "STR" "") (setq pt1 (getpoint "L型梯左下角点:")) (setq pt2 (polar pt1 0 ww)) (setq pt3 (polar pt2 (* pi 0.5) hh)) (setq pt4 (polar pt3 pi (* ww 0.5))) (setq pt5 (polar pt4 (* pi 1.5) (* hh 0.5))) (setq pt6 (polar pt5 pi (* ww 0.5))) (command "pline" pt1 pt2 pt3 pt4 pt5 pt6 "c") (dim_dia9c) ) (defun dim_dia9c() (command "-layer" "m" "DIM" "c" 3 "DIM" "") (command "dim" "hor" pt1 pt2 (polar pt1 (* pi 1.5) 10) "" "exit") (command "dim" "ver" pt2 pt3 (polar pt2 0 10) "" "exit") ) 结果是运行不出结果来! 不知道原因在那里??望高人告诉我!! |
