LISP程序如下: (defun c:dia6b() (setvar "cmdecho" 0) (setq blkname "dia6att") (dcl_dia6b) (prin1) ) (defun dcl_dia6b() (setq dcl_id (load_dialog "dia6b")) (new_dialog "dia6b" dcl_id) (setq defkey1 "rb14" defkey2 "rb21") (set_tile defkey1 "1") (set_tile defkey2 "1") (setq name (get_attr defkey1 "label")) (setq ssca (get_attr defkey2 "label")) (action_tile "rb11" "(setq name (get_attr $key\"label\"))") (action_tile "rb12" "(setq name (get_attr $key\"label\"))") (action_tile "rb13" "(setq name (get_attr $key\"label\"))") (action_tile "rb14" "(setq name (get_attr $key\"label\"))") (action_tile "rb21" "(setq ssca (get_attr $key\"label\"))") (action_tile "rb22" "(setq ssca (get_attr $key\"label\"))") (action_tile "rb23" "(setq ssca (get_attr $key\"label\"))") (action_tile "rb24" "(setq ssca (get_attr $key\"label\"))") (action_tile "rb25" "(setq ssca (get_attr $key\"label\"))") (action_tile "ins_ok" "(ok_dia6b) (done_dialog 1)") (setq dd (start_dialog)) (if (= dd 1) (progn (setq inspt (getpoint "\n选取属性图块插入点:")) (command "insert" blkname inspt 1 1 0 dwgnum name ssca) ) ) ) (defun ok_dia6b() (setq dwgnum (get_tile "dwgnum")) ) DCL语句如下: dia6b:dialog{ label="轻松掌握单选按钮"; :text{label="[插入带有属性的图块DIA6B]"; alignment=centered; } :row{ :boxed_radio_column{ label="设计者"; :radio_button{label="忍者鬼";key="rb11";} :radio_button{label="小叮当";key="rb12";} :radio_button{label="钟楼怪人";key="rb13";} :radio_button{label="无敌铁金刚";key="rb14";} } :boxed_radio_column{ label="比例"; :radio_button{label="1/1";key="rb21";} :radio_button{label="1/30";key="rb22";} :radio_button{label="1/50";key="rb23";} :radio_button{label="1/100";key="rb24";} :radio_button{label="1/200";key="rb25";} } } :edit_box{ label="图档编号"; key="dwgnum"; edit_width=8; edit_limit=8; fixed_width=true; } spacer_1; :row{ fixed_width=true; alignment=centered; :button{ label="插入图块"; key="ins_ok"; width=8; } :spacer{width=2;} cancel_button; } } 加载后出现如下提示: 选取属性图块插入点:未知命令“A100”。按 F1 查看帮助。 未知命令“无敌铁金刚”。按 F1 查看帮助。 未知命令“1/30”。按 F1 查看帮助。 就是得不到我所要的结果!请问是什么原因?? |
