各位大虾,我写的下面一段代码,在cad中运行,会出现类rang的select方法无效,请各位大虾执教!!!谢谢!!! Set rg = newexcel.Sheets(1).Range(newexcel.Sheets(1).Cells(10, 18), newexcel.Sheets(1).Cells(10, 21)) rg.Select With Selection.Borders(xlEdgeTop) .LineStyle = xlContinuous .Weight = xlThin .ColorIndex = xlAutomatic End With rg.Merge rg.HorizontalAlignment = xlCenter rg.VerticalAlignment = xlCenter rg.WrapText = True End If
