各位兄弟,你们好! 帮我看看这个土方计算程序为什么不能用啊,我加载这个程序后,选择闭合线及高程时, 出现什么除数为0,不能生成网格线。望各位测绘兄弟帮我看看,兄弟感谢了 (defun c:tf (/ a nb np hr n i ai b la h hi s p p1) (princ "选择高程及面积:") (setq a (ssget '((0 . "text")))) (setq na 0) (setq nb 0) (setq hp 0) (setq hr 0) (setq n (sslength a)) (setq i 0) (repeat n (setq ai (ssname a i)) (setq i (+ i 1)) (setq b (entget ai)) (setq la (cdr (assoc 8 b))) (setq h (cdr (assoc 1 b))) (setq hi (atof h)) (if (or (= la "YGC") (= la "ygc") ) (progn (setq na (+ na 1)) (setq hp (+ hp hi)) ) ) (if (or (= la "XGC") (= la "xgc") ) (progn (setq nb (+ nb 1)) (setq hr (+ hr hi)) ) ) (if (or (= la "MJ") (= la "mj") ) (progn (setq s (substr h 3)) (setq s (atof s)) (setq p (cdr (assoc 10 b))) (setq p1 (polar p 2 2)) ) ) ) (setq hp (/ hp na)) ;(setq hp 11) (setq hr (/ hr nb)) (setq v 0) (setq v (* s (- hr hp))) (setq v (rtos v 2 2)) (setq s (strcat "V=" v)) (setq pt1 (mapcar '+ pt1 '(0.8 0 0) ) ) (setq e (list (cons 0 "text") (cons 1 s) (cons 10 p1) (cons 40 0.8))) (entmake e) ) (defun c:v () (setq a (ssget '((0 . "TEXT")))) (setq n (sslength a)) (setq i 0) (setq s 0) (repeat n (setq ai (ssname a i)) (setq i (+ i 1)) (setq b (entget ai)) (setq attr (cdr (assoc 0 b))) (if (= attr "TEXT") (progn (setq t (cdr (assoc 1 b))) (if (< (atof t) 0.000001) (progn (setq si (atof (substr t 3))) (setq s (+ s si)) ) ) ) ) ) (setq p (getpoint "s_location:")) (setq s (strcat "V=" (rtos s 2 2))) (command "text" p 1 "" s) )(defun c:s () (setq a (ssget '((0 . "TEXT")))) (setq n (sslength a)) (setq i 0) (setq s 0) (repeat n (setq ai (ssname a i)) (setq i (+ i 1)) (setq b (entget ai)) (setq attr (cdr (assoc 0 b))) (if (= attr "TEXT") (progn (setq t (cdr (assoc 1 b))) (if (< (atof t) 0.000001) (progn (setq si (atof (substr t 3))) (setq s (+ s si)) ) ) ) ) ) (setq p (getpoint "s_location:")) (setq s (strcat "S=" (rtos s 2 2))) (command "text" p 1 "" s) ) (defun c:aa (/ p a s) (setq e (entlast)) (setq p (getpoint "input text point:")) (command "BOUNDARY" p "") (if (equal e (entlast)) (alert "BOUNDARY ERROR !") (progn (command "AREA" "O" "LAST") (entdel (entlast)) (setq a (getvar "AREA")) ;(setq zzza(/ a 666.66667)) ;(setq zzza(rtos zzza 2 2)) ;(setq zzza(strcat "(合" zzza "亩)")) (setq s (rtos a 2 2)) (setq s (strcat "S=" S)) ;(setq s (strcat s "平方米" zzza)) (command "text" p "0.8" "" s) ) ) ) (defun c:ygc () (setq pt1 (getpoint "输入设计高点位?")) (setq pt1 (mapcar '+ pt1 '(0.6 -1.5 0) ) ) (setq str "7.10") (setq e (list (cons 0 "text") (cons 1 str) (cons 8 "YGC") (cons 10 pt1) (cons 40 1) ) ) (entmake e) ) (defun c:xgc () (setq pt1 (getpoint "点位?")) (setq pt1 (mapcar '+ pt1 '(0.6 1.5 0) ) ) (setq str (getstring "Enter text:")) (setq e (list (cons 0 "text") (cons 1 str) (cons 8 "XGC") (cons 10 pt1) (cons 40 1) ) ) (entmake e) ) (defun tfxyz (ssent / len k ai g xyz x y z dxfvl vl) (setq vl '()) (if ssent (progn (setq len (sslength ssent) k 0 ) (repeat len (setq ai (ssname ssent k) k (1+ k) ) (setq g (entget ai)) (setq xyz (cdr (assoc 10 g)) x (car xyz) y (cadr xyz) ) (if (equal (strcase typ) "TEXT") (setq z (atof (cdr (assoc 1 g)))) (setq z (caddr xyz)) ) (setq dxfvl (list x y z)) (setq vl (append vl (list dxfvl) ) ) ) ) (setq vl nil) ) (setq vl vl) ) (defun tfapf (fna str) (setq fn (open fna "a")) (princ str fn) (close fn) ) (defun c:zz (/ pa pb a b pc ab ac c) (setq pa (getpoint "Specify first point:") pb (getpoint "Specify second point:") a (getreal "Specify first High:") b (getreal "Specify second High:") ) (while (setq pc (getpoint "Specify start point:") ab (distance (list (car pa) (cadr pa)) (list (car pb) (cadr pb) ) ) ac (distance (list (car pa) (cadr pa)) (list (car pc) (cadr pc) ) ) c (+ a (* ac (/ (- b a) ab))) ) (setq e (list (cons 0 "TEXT") (cons 1 (rtos c 2 2)) (cons 8 "YGC") (cons 10 pc) (cons 40 1.0) (cons 62 1) ) ) (entmake e) ) ) (defun tftext (tf_la hh cc / pc c e) (setq pc (getpoint) c (getreal) ) (setq e (list (cons 0 "TEXT") (cons 1 (rtos c 2 2)) (cons 8 tf_la) (cons 10 pc) (cons 40 hh) (cons 62 cc) ) ) (entmake e) ) (defun c:xx () (tftext "sdg" 1.0 1)) (defun c:ss () (tftext "sjg" 1.5 6)) (defun c:bb (/ a b pa pb ab c e) (setq a (getreal "高程:") b (getreal "请输入比例系数:") pa (getpoint "起点:") ) (while (setq pb (getpoint "到下一个点文本位置:") ab (distance (list (car pa) (cadr pa)) (list (car pb) (cadr pb) ) ) c (+ a (* ab b)) ) (setq e (list (cons 0 "TEXT") (cons 1 (rtos c 2 2)) (cons 8 "YGC") (cons 10 pb) (cons 40 8.0) (cons 62 1) ) ) (entmake e) ) ) (defun c:sdg (/ i lts typ i p0 d str sd sj e px py pe z lts) (setvar "dimzin" 3) (SETQ TYP "TEXT") (prompt "起点距离") (setq i (getdist)) (prompt "剖面线起点:") (while (setq p0 (getpoint)) (setq d (strcat "0+" (rtos i 2 2) "\n")) (tfapf "d:/sdg.txt" d) (tfapf "d:/sjg.txt" d) (setq str (ssget '((0 . "TEXT")))) (setq sd (ssget "p" '((8 . "sdg")))) (command "select" str "") (setq sj (ssget "p" '((8 . "sjg")))) (command "chprop" str "" "c" 2 "") (foreach e (tfxyz sd) (setq px (car p0) py (cadr p0) p0 (list px py) ) (setq pe (list (car e) (cadr e))) (setq d (distance p0 pe)) (setq d (rtos d 2 2)) (setq z (rtos (caddr e) 2 2)) (tfapf "d:/sdg.txt" d) (tfapf "d:/sdg.txt" " ") (tfapf "d:/sdg.txt" z) (tfapf "d:/sdg.txt" "\n") ) (foreach e (tfxyz sj) (setq px (car p0) py (cadr p0) p0 (list px py) ) (setq pe (list (car e) (cadr e))) (setq d (distance p0 pe)) (setq d (rtos d 2 2)) (setq z (rtos (caddr e) 2 2)) (tfapf "d:/sjg.txt" d) (tfapf "d:/sjg.txt" " ") (tfapf "d:/sjg.txt" z) (tfapf "d:/sjg.txt" "\n") ) (prompt "请量取到下一根剖面线的距离") (setq lts (getdist)) (setq i (+ lts i)) (prompt "剖面线起点:") ) ) |
