查看: 1522|回复: 1
你的代码我运行后宏显示框中是空白,我没有办法运行,是怎么回事?
发表于 2003-4-16 00:11:00 | 显示全部楼层 |阅读模式
Private Sub AcadDocument_BeginDoubleClick(ByVal PickPoint As Variant)
    Dim Bp, Ep As Variant
     Bp = ThisDrawing.Utility.GetPoint(, "选择端点: ")
     Ep = ThisDrawing.Utility.GetPoint(Bp, "选择终点: ")
     Dim obj As AcadLine
     Set obj = ThisDrawing.ModelSpace.AddLine(Bp, Ep)
End Sub
发表于 2003-4-16 23:15:00 | 显示全部楼层
因为这是个事件,是通过双击鼠标来触发
GMT+8, 2025-5-23 13:14 , Processed in 0.173681 second(s), 23 queries , Gzip On.
