原程序: (defun C:zhl_TP (/ p l n e os as ns st s nsl osl sl si chf chm chm2 olderr) ; (princ "\n本程序快捷键为 tp !\n") (setq olderr *error* ; Initialize variables *error* tperr chm 0 chm2 0) (setq p (ssget '((0 . "*TEXT")))) ; Select objects (if p (progn ; If any objects selected (while (= 0 (setq osl (strlen (setq os (getstring t "\n请输入要查找的文字:"))))) (princ "输入错误,请重新输入!") );while (setq nsl (strlen (setq ns os))) (setq l 0 n (sslength p)) (while (< l n) ; For each selected object... (if (= "TEXT" (cdr (assoc 0 (setq e (entget (ssname p l)))))) (progn (setq chf nil si 1) (setq s (cdr (setq as (assoc 1 e)))) (while (= osl (setq sl (strlen (setq st (substr s si osl))))) (if (= st os) (progn (setq s (strcat (substr s 1 (1- si)) ns (substr s (+ si osl)))) (setq chf t) ; Found old string (setq si (+ si nsl)) ) (setq si (1+ si)) ) );while (if chf (progn ; Fixed at the text and zoom to it (setq pc (list (nth 1 (assoc 10 e)) (nth 2 (assoc 10 e)) 0) ) (setq th (* 30 (cdr (assoc 40 e)) ) ) (command "zoom" "c" pc th) (initget "Next Xit") (setq key (getkword "\n选择显示下一个或退出,N下一个/X退出/ <N下一个>:")) (if (not key) (setq key "NEXT")) (if (= (strcase key) "XIT") (setq l n chm (1+ chm) ) ) (if (= (strcase key) "NEXT") (setq chm (1+ chm)) );if );progn );if );progn );if (setq l (1+ l)) );while (setq l 0 chm2 0) (while (< l n) ; For each selected object... (if (= "TEXT" (cdr (assoc 0 (setq e (entget (ssname p l)))))) (progn (setq chf nil si 1) (setq s (cdr (setq as (assoc 1 e)))) (while (= osl (setq sl (strlen (setq st (substr s si osl))))) (if (= st os) (progn (setq s (strcat (substr s 1 (1- si)) ns (substr s (+ si osl)))) (setq chf t) ; Found old string (setq si (+ si nsl)) ) (setq si (1+ si)) ) );while (if chf (setq chm2 (1+ chm2)) );if );progn );if (setq l (1+ l)) );while ));ifprogn (princ "\n共有 ") (princ chm2) (princ " 个定位点,目前定位在第 ") ; Print total points fixed (princ chm) (princ " 个定位点,定位完成!") ; (terpri) (setq *error* olderr) ; Restore old *error* handler (princ) ) 想做成这样的对话框: 对话框: |
