查看: 1719|回复: 0
[原创]缩放圆VBA源码
发表于 2007-4-21 15:01:00 | 显示全部楼层 |阅读模式
Private Sub CommandButton1_Click()
UserForm1.Hide
On Error Resume Next
    Dim sset As AcadSelectionSet
    If Not IsNull(ThisDrawing.SelectionSets.Item("Example")) Then
        Set sset = ThisDrawing.SelectionSets.Item("Example")
        sset.Delete
    End If
    Set sset = ThisDrawing.SelectionSets.Add("Example")
sset.SelectOnScreen
' 在选择集中循环并将每一对象的颜色改为蓝色。
Dim entry As AcadEntity
For Each entry In sset
entry.color = acRed
entry.Offset (CDbl(UserForm1.TextBox1.text))
entry.color = acWhite
entry.Update
Next entry
  If UserForm8.CheckBox1.Value = True Then
    For Each element In sset
      element.Delete
    Next
  End If
    sset.Delete
    End
End Sub
上面VBA代码,怎样可以改成VB代码,明经兄弟请帮忙
GMT+8, 2025-5-2 05:24 , Processed in 0.137359 second(s), 23 queries , Gzip On.
