查看: 1837|回复: 3
高手可以帮忙看看,找错误
发表于 2003-4-17 09:23:00 | 显示全部楼层 |阅读模式
Option Explicit
Const pi = 3.14159
Dim point(0 To 2) As Double, point2(0 To 2) As Double
Dim textposition(0 To 2) As Double
Dim center(0 To 2) As Double, radius As Double
Dim offset As Double
Private Sub cmdexit_click()
   Unload Me
End Sub
Private Sub userform_initialize()
   point1(0) = 1#: point1(1) = 1#: point1(2) = 0#
   point2(0) = 5#: point2(1) = 1#: point2(2) = 0#
   offset = 0.25
   textposition(0) = 2#
   textposition(1) = 1# + offset
   textposition(2) = 0#
   center(0) = 0#: center(1) = 0#: center(2) = 0#
   radius = 2#
End Sub
Private Sub opt3pointangular_Click()
   Dim dimensionobject As AcadDim3PointAngular
   Dim circleobject As AcadCircle
   Dim firstendpoint(0 To 2) As Double
   Dim secondendpoint(0 To 2) As Double
   Set circleobject = ThisDrawing.ModelSpace.AddCircle(center, radius)
   circleobject.Update
   firstendpoint(0) = center(0) + radius
   firstendpoint(1) = center(1)
   firstendpoint(2) = center(2)
   secondendpoint(0) = center(0) + radius * Cos(45 * pi / 180)
   secondendpoint(1) = center(1) + radius * Sin(45 * pi / 180)
   secondendpoint(2) = center(2)
   Set dimensionobject = ThisDrawing.ModelSpace.AddDim3PointAngular _
                         (center, firstendpoint, secondendpoint, textposition)
   dimensionobject.AngleFormat = acDegrees
   dimensionobject.Update
   ZoomAll
End Sub
Private Sub optangular_Click()
   Dim dimensionobject As AcadDimAngular
   Set circleobject = thhisdrawing.ModelSpace.AddCircle(center, radius)
   circleobject.Update
   Set dimensionobject = ThisDrawing.ModelSpace.AddDimAngular _
   ZoomAll
End Sub
Private Sub optdiametric_Click()
   Dim dimensionobject As AcadDimDiametric
   Dim lineobject As AcadLine
   Dim chordpoint(0 To 2) As Double, farchordpoint(0 To 2) As Double
   circleobject.Update
   chordpoint(0) = center(0) + radius * Cos(45 * pi / 180)
   chordpoint(1) = center(1) + radius * Sin(45 * pi / 180)
   chordpoint(2) = center(2)
   farchordpoint(0) = center(0) + radius * Cos(225 * pi / 180)
   farchordpoint(1) = center(1) + radius * Sin(225 * pi / 180)
   farchordpoint(2) = center(2)
   Set lineobject = ThisDrawing.ModelSpace.AddLine(chordpoint, farchordpoint)
   lineobject.Update
   Set dimensionobject = ThisDrawing.ModelSpace.AddDimDiametric _
                         (chordpoint, farchordpoint, 1.5)
   ZoomAll
End Sub
Private Sub optordinate_Click()
   Dim dimensionobject As AcadDimOrdinate
   Dim definitionpoint(0 To 2) As Double
   Dim leaderendpoint(0 To 2) As Double
   Set lineobject = ThisDrawing.ModelSpace.AddLine(point1, point2)
   lineobject.Update
   definitionpoint(0) = (point1(0) + point2(0)) / 2#
   definitionpoint(1) = (point1(1) + point2(1)) / 2#
   definitionpoint(2) = (point1(2) + point2(2)) / 2#
   leaderendpoint(0) = definitionpoint(0)
   leaderendpoint(1) = definitionpoint(1) + 2#
   leaderendpoint(2) = definitionpoint(2)
   Set dimensionobject = ThisDrawing.ModelSpace.AddDimOrdinate _
                         (definitionpoint, leaderendpoint, True)
   dimensionobject.ExtensionLineOffset = offset
   ZoomAll
End Sub
Private Sub optradial_Click()
   Dim dimensionobject As AcadDimRadial
   circleobject.Update
   Set lineobject = ThisDrawing.ModelSpace.AddLine(center, chordpoint)
   lineobject.Update
   Set dimensionobject = ThisDrawing.ModelSpace.AddDimRadial(center, chordpoint, 1.25)
   ZoomAll
End Sub
Private Sub optrotated_Click()
   Dim dimensionobject As AcadDimRotated
   Dim dimlinelocation(0 To 2) As Double
   dimlinelocation(0) = point1(0) - 1#
   dimlinelocation(1) = point1(1)
   dimlinelocation(2) = point1(2)
   lineobject.Update
   Set dimensionobject = ThisDrawing.ModelSpace.AddDimRotated _
                         (point1, point2, dimlinelocation, (45 * pi / 180))
   ZoomAll
End Sub
Private Sub optaligned_Click()
   Dim dimensionobject As AcadDimAligned
   lineobject.Update
   Set dimensionobject = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, textposition)
dimensionobject.ArrowheadSize = 0.5
dimensionobject.Color = acCyan
ThisDrawing.Preferences.LineWeightDisplay = True
dimensionobject.DimensionLineWeight = acLnWt030
   ZoomAll
End Sub
发表于 2003-4-17 19:10:00 | 显示全部楼层
你连注释都不写,让我们怎么看??也不知你是哪抄的程序??
 楼主| 发表于 2003-4-17 21:32:00 | 显示全部楼层
呵呵
不好意思,我不知道!
哪个是一个标注的程序,基本感觉没什么问题,可是就是运行不了
老是子函数未定义哦
HELPPPPPPPPPPP
发表于 2003-4-17 21:44:00 | 显示全部楼层
这么多的按钮,不会每一个都出问题吧,你把出问题的那个说出来
GMT+8, 2025-10-29 04:33 , Processed in 0.158351 second(s), 23 queries , Gzip On.
