查看: 5576|回复: 4
用excel中的数据绘图
发表于 2007-5-11 15:26:00 | 显示全部楼层 |阅读模式
哪位高手帮忙看一下下面的程序有什么问题,总是运行不对,先谢谢了!
Private Sub draw()
          Dim xlsApp     As Excel.Application
          Dim eworkbook     As Workbook
          Dim eworksheet     As Worksheet
          Dim cir As AcadEntity
          Dim b(0 To 2) As Double
          Dim c  As Double
          Dim x As Acad3DSolid
          Dim d As Double
          Dim e As Double
          Dim re As Variant
          Dim height As Double
            hight = 500
            e = 0
          Set xlsApp = New Excel.Application
          Set eworkbook = xlsApp.Workbooks.Open("F:\国道112\坐标.xls")
          Set eworksheet = eworkbook.Sheets("8标的桥位坐标表")
            For i = 4 To 118
             With eworksheet
                 b(0) = .Cells(i, 4)
                 b(1) = .Cells(i, 5)
                 b(2) = .Cells(i, 6)
                    c = .Cells(i, 7)
             End With
             Set cir = ThisDrawing.ModelSpace.addcircle(b, c)
             re = ThisDrawing.ModelSpace.AddRegion(cir)
          Set x = ThisDrawing.ModelSpace.AddExtrudedSolid(re, height, e)
             Next i
             ZoomAll
          eworkbook.Close
          xlsApp.Quit
         End Sub
发表于 2010-5-30 16:49:00 | 显示全部楼层
新手,路过,学习中.不能给你答案了.
发表于 2010-6-3 10:26:00 | 显示全部楼层
 Set x = ThisDrawing.ModelSpace.AddExtrudedSolid(re, height, e)改为
 Set x = ThisDrawing.ModelSpace.AddExtrudedSolid(re(0), height, e)?
发表于 2011-4-2 13:06:58 | 显示全部楼层
我正在初学中,无法解决这个问题。
发表于 2011-12-11 22:45:49 | 显示全部楼层
太过于深奥。请求高手。。
GMT+8, 2025-4-29 06:15 , Processed in 0.168407 second(s), 23 queries , Gzip On.
