查看: 1095|回复: 2
[求助]关于比例尺的问题
发表于 2007-5-11 17:39:00 | 显示全部楼层 |阅读模式
编了个坐标变换的小程序,用来改变坐标,坐标变换后就可以在图中直接查某点的坐标,但却遇到个问题,比如图为10000时,要查232300这个点,显示却为23230,如何解决?
(defun c:myucs ()
(setq pp (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq pt1 (getreal "请输入N(X)坐标:"))
(setq pt2 (getreal "\n请输入E(Y)坐标:"))
(setq blc1 (getreal "\n请输入N(X)比例尺:"))
(setq blc2 (getreal "\n请输入E(Y)比例尺:"))
(setq pt11 (* (/ pt1 blc1) 1000))
(setq pt22 (* (/ pt2 blc2) 1000))
(setq pt3 (- 0 pt11))
(setq pt4 (- 0 pt22))
(setq pt5 (list pt3 pt4 0))
(command "UCS" "_3" (getpoint "选取一点:") (getpoint "\n确定X方向:") (getpoint "\n确定Y方向:") "")
(command "UCS" "_move" pt5)
(command "")
(setvar "cmdecho" pp)
 楼主| 发表于 2007-5-14 13:03:00 | 显示全部楼层
没有人知道吗?
发表于 2007-5-14 19:37:00 | 显示全部楼层
GMT+8, 2025-7-2 13:28 , Processed in 0.142994 second(s), 25 queries , Gzip On.
