查看: 1907|回复: 1
[求助]帮我看一下块加属性代码?
发表于 2007-5-16 14:13:00 | 显示全部楼层 |阅读模式
void insertblock()
 AcGePoint3d pt1;
 CString blk_name="testblock";
 CString Fname=blk_name+".dwg";
 char sFileName[160];
 const char *dwgName=(LPSTR)(LPCTSTR)Fname;
 acedFindFile(dwgName,sFileName);
 AcDbDatabase *pNewDb =new AcDbDatabase(Adesk::kFalse);
 int es=pNewDb->readDwgFile(sFileName ,_SH_DENYNO,false);
 if (es!=Acad::eOk)
 acutPrintf("\nThe file %s cannot be opend",sFileName);
 return;
 AcDbDatabase *pDb;
 pDb =acdbHostApplicationServices ()->workingDatabase () ;
 AcDbObjectId blockId;
 if((es=pDb->insert(blockId, blk_name,pNewDb, true))==Acad::eOk)
 acutPrintf("\ninsert ok\n");
 else
 AfxMessageBox("Insert failed");
 delete pNewDb;
  return;
 if(RTNORM!=acedGetPoint(NULL,"\n请输入插入点:",asDblArray(pt1)))
  return;
 AcDbBlockTable *pBlockTable;
 AcDbBlockTableRecord *pBlockTableRecord;
 acdbHostApplicationServices()->workingDatabase()
        ->getSymbolTable(pBlockTable, AcDb::kForRead);
 pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite);
 pBlockTable->getAt(blk_name, blockId);
 pBlockTable->add(blockId,pBlockTableRecord);
 pBlockTable->close();
 AcDbBlockReference *pBlkRef = new AcDbBlockReference;
 pBlkRef->setBlockTableRecord(blockId);//指向blockId;
 pBlkRef->setPosition(pt1);//设定位置
 pBlkRef->setRotation(0);//设定转角
 AcDbObjectId newEntId;
 pBlockTableRecord->appendAcDbEntity(newEntId, pBlkRef);
 pBlockTableRecord->close();
 pBlkRef->close();
 AcDbBlockTableRecord *pblockrec;
 acdbOpenObject(pblockrec,blockId,AcDb::kForWrite);
 AcDbAttributeDefinition *pAttriDef=new AcDbAttributeDefinition;
 pAttriDef->setPrompt("aa");
 pAttriDef->setTextString("a");
 pAttriDef->setTag("Tag");
 pAttriDef->setInvisible(Adesk::kFalse);
 pAttriDef->setPreset(Adesk::kFalse);
 pAttriDef->setConstant(Adesk::kFalse);
 pblockrec->appendAcDbEntity(newEntId,pAttriDef);
 pAttriDef->close();
 pblockrec->close();
插入一个外部块,然后给这个块加块属性,但是属性却看不到,炸开却有块属性在。这是什么问题?
发表于 2007-7-18 11:54:00 | 显示全部楼层
遇到了同样的问题
块里有块,内部块的属性值修改不了。
怎么办?
GMT+8, 2025-5-25 18:34 , Processed in 0.172506 second(s), 24 queries , Gzip On.
