查看: 1872|回复: 2
高手帮我看看程序吧,在线等,谢谢!
发表于 2007-5-16 17:59:00 | 显示全部楼层 |阅读模式
画了一个正方形,想填充一下,调试通过了,但是已运行arx就报错!高手帮我分析分析吧,多谢了!
Acad::ErrorStatus createSubstationRecord () {
 AcDbHatch* pHatch = new AcDbHatch();
 // Set hatch plane
 AcGeVector3d normal(0.0, 0.0, 1.0);
 pHatch->setNormal(normal);
 pHatch->setElevation(0.0);
 // Set hatch pattern to ANSI31 predefined type
 pHatch->setPattern(AcDbHatch::kPreDefined, "ANSI31");
 // Set Associativity
 pHatch->setAssociative(Adesk::kTrue);
 AcGePoint3dArray ptSubstation;
 ptSubstation.setLogicalLength(4);
 ptSubstation[0].set(0.0,0.0,0.0);
 ptSubstation[1].set(0.0,100.0,0.0);
 ptSubstation[2].set(100.0,100.0,0.0);
 ptSubstation[3].set(100.0,0.0,0.0);
 AcDbObjectId lineId,;
 AcDbObjectIdArray dbObjIds;
 AcDbLine *pline;
 for (int i = 0; i < 4; i++) {
  pline =  new AcDbLine();
  pline->setStartPoint(ptSubstation);
  pline->setEndPoint(ptSubstation[(i == 3) ? 0 : i+1]);
  postToDatabase(pline, lineId);
  dbObjIds.append(lineId);
 // Append an external rectangular loop to hatch boundary
 pHatch->appendLoop(AcDbHatch::kExternal, dbObjIds);
 pHatch->evaluateHatch();
 return Acad::eOk;
////////下面是Post函数
Acad::ErrorStatus
postToDatabase(/*[in]*/AcDbEntity* pEnt,/*[out]*/AcDbObjectId& idObj)
 Acad::ErrorStatus   es;
 AcDbBlockTable*  pBlockTable;
 AcDbBlockTableRecord*  pSpaceRecord;
 //确定当前有正在工作的数据库
 if (acdbHostApplicationServices()->workingDatabase()==NULL)
  return Acad::eNoDatabase;
 //获得当前图形的指针
 //获得图形的块表,打开准备读取数据
 if ((es = acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlockTable, AcDb::kForRead))==Acad::eOk){
  //获得建模空间的记录,打开准备写数据
  if ((es = pBlockTable->getAt(ACDB_MODEL_SPACE, pSpaceRecord, AcDb::kForWrite))==Acad::eOk){
   //添加实体指针到建模空间后关闭指针和建模空间记录
   if ((es = pSpaceRecord->appendAcDbEntity(idObj, pEnt))==Acad::eOk)
    pEnt->close();
   pSpaceRecord->close();
  //关闭块表
  pBlockTable->close();
 //返回状态信息
 return es;
发表于 2007-5-16 21:15:00 | 显示全部楼层
调试通过了????????????????????
AcDbObjectId lineId,;多一个逗号
后面加如下(填充还没有提交到数据库)
  AcDbObjectId hatchId;
  postToDatabase(pHatch, hatchId);
 楼主| 发表于 2007-5-17 13:07:00 | 显示全部楼层
谢谢sieben的回复,帮助很大,但是怎么把花的图形和填充图案,通过程序保存为一个块呢!请求大家帮助
GMT+8, 2025-5-25 16:53 , Processed in 0.165414 second(s), 24 queries , Gzip On.
