查看: 1567|回复: 1
用VBA编程以后出现图形退化,程序代码如下,请教一下,是怎么回事?
发表于 2007-5-18 15:34:00 | 显示全部楼层 |阅读模式
问一下,图形退化是怎么回事?
程序如下:
Private Sub draw()
          '引用   Microsoft   Excel   11.0   Object   Library
          Dim xlsApp     As Excel.Application
          Dim eworkbook     As Workbook
          Dim eworksheet     As Worksheet
          Dim cir(0 To 1) As AcadEntity
          Dim b(0 To 2) As Double, g(0 To 2) As Double
          Dim c  As Double
          Dim x As Acad3DSolid
          Dim d As Double
          Dim e As Double
          Dim f As Double
          Dim re As Variant
          Dim height(0 To 1) As Double
            e = 0
          Set xlsApp = New Excel.Application
          Set eworkbook = xlsApp.Workbooks.Open("F:\国道112\坐标.xls")
          Set eworksheet = eworkbook.Sheets("8标的桥位坐标表")
          For j = 4 To 20
            For i = 4 To 118
             With eworksheet
                 b(0) = .Cells(i, j)
                 b(1) = .Cells(i, j + 1)
                 b(2) = .Cells(i, j + 2)
                    c = .Cells(i, j + 3)
                    height(0) = .Cells(i, j + 4)
                 g(0) = .Cells(i + 1, j)
                 g(1) = .Cells(i + 1, j + 1)
                 g(2) = .Cells(i + 1, j + 2)
                    f = .Cells(i + 1, j + 3)
                    height(1) = .Cells(i + 1, j + 4)
             End With
             Set cir(0) = ThisDrawing.ModelSpace.addcircle(b, c)
             Set cir(1) = ThisDrawing.ModelSpace.addcircle(g, f)
             re = ThisDrawing.ModelSpace.AddRegion(cir)
          Set x = ThisDrawing.ModelSpace.AddExtrudedSolid(re(0), -height(0), e) '此中的re(0),即acadregion必须为一个域,而不是一个数组。
          Set x = ThisDrawing.ModelSpace.AddExtrudedSolid(re(1), -height(1), e)
              i = i + 2
              Next i
              j = j + 16
              Next j
             ZoomAll
             eworkbook.Close
             xlsApp.Quit
          'eworkbook.Save
          Set xlsApp = Nothing
          Set eworkbook = Nothing
          Set eworksheet = Nothing
         End Sub
哪位高手给看一下是哪出问题了?
发表于 2007-5-19 11:36:00 | 显示全部楼层
图形退化?不懂!
GMT+8, 2025-7-15 04:16 , Processed in 0.229331 second(s), 23 queries , Gzip On.
