如:(SETQ GTQQ(LIST 1 1 1))(SETQ LTQQ '((51 17 32) (28 42 68) (53 25 19) (12 25 89)) )求出: _$ (53 42 89)
可以用下列程序求出(MAPCAR '(LAMBDA (X) (SETQ GTQQ(LIST (MAX (CAR GTQQ)(CAR X))(MAX(CADR GTQQ)(CADR X))(MAX(CADDR GTQQ)(CADDR X))))) LTQQ)
但是如果为下面这样的串列,非固定的串列值,该怎样处理呢?(SETQ LSPNB '((11 4 8 17 2 20 22 7 5 12) (5 10 2 17 1 20 22 7 5 12) (9 6 6 17 1 20 22 7 5 12) (9 6 6 17 1 20 22 7 5 12) (3 12 17 1 4 11 3 22 7 5 12) (9 6 6 17 1 6 13 22 7 5 12) (7 8 4 17 1 20 22 7 5 12) (9 6 6 17 1 4 11 3 22 7 5 12) (7 8 4 17 1 4 11 3 22 7 5 12) (9 6 6 17 1 4 11 3 22 7 5 12) (1 13 1 15 1 16 3 22 7 5 12) (7 8 4 17 1 4 11 3 22 7 5 12) (13 2 14 1 4 11 3 22 7 5 12) (3 12 1 16 4 4 11 3 20 2 6 6 11) (7 8 5 16 4 4 11 3 20 2 6 6 11) (5 10 3 16 4 20 20 2 6 6 11) (15 13 16 4 20 20 2 6 6 11) (1 14 4 13 16 4 20 16 3 2 6 6 11) (10 16 2 20 20 2 6 6 11) (10 16 2 20 20 2 6 6 11) (11 14 17 1 1 20 20 2 6 6 11) (3 12 1 16 2 4 15 20 2 6 6 11) (13 2 10 16 4 20 20 2 6 6 11) (24 18 1 10 18 2 20 22 7 5 12)) )
烦请各位帮忙解答一下谢谢!!!
I don't understand your intention.
I loaded your sample code
(SETQ GTQQ (LIST 1 1 1))(SETQ LTQQ '((51 17 32) (28 42 68) (53 25 19) (12 25 89) ))(MAPCAR '(LAMBDA (X) (SETQ GTQQ (LIST (MAX (CAR GTQQ) (CAR X)) (MAX (CADR GTQQ) (CADR X)) (MAX (CADDR GTQQ) (CADDR X)) ) ) ) LTQQ) and got
((51 17 32) (51 42 68) (53 42 68) (53 42 89))
Consider the function vl-sort
真是利害
還可以這樣解
謝謝您的解答
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2024-5-19 03:45 , Processed in 0.239412 second(s), 25 queries , Gzip On.
