查看: 3171|回复: 1
各位高手:添加一多义线并设置线型错在什么地方
发表于 2007-5-21 21:41:00 | 显示全部楼层 |阅读模式
 '绘多义线
    <CommandMethod("AddPL")> _
        Public Sub AddPL()
        Dim pl As New Polyline
        Dim DB As Database
        Dim trans As Transaction
        Dim btr As BlockTableRecord
        Dim bt As BlockTable
        'Dim li As Object
        DB = HostApplicationServices.WorkingDatabase
        trans = DB.TransactionManager.StartTransaction
        bt = trans.GetObject(DB.BlockTableId, OpenMode.ForWrite)
        btr = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
        'Dim pLinetypeTbl As LinetypeTable = trans.GetObject(DB.LinetypeTableId, OpenMode.ForRead)
        'If pLinetypeTbl.Has("DASHDOT") Then
            'DB.LoadLineTypeFile("DASHDOT", "acadiso.lin")
            'End If
            Dim point2D(2) As Point2d
            point2D(0) = New Point2d(10, 10)
            point2D(1) = New Point2d(10, 5)
            point2D(2) = New Point2d(30, 40)
            pl.AddVertexAt(0, point2D(0), 0, 1, 1)
            pl.AddVertexAt(1, point2D(1), 0, 1, 1)
        pl.AddVertexAt(2, point2D(2), 0, 1, 1)
        pl.LinetypeId = CreatLineType("DASHDOT")
            ' pl.Linetype = "DASHDOT"
            btr.AppendEntity(pl)
            trans.AddNewlyCreatedDBObject(pl, True)
            trans.Commit()
            trans.Dispose()
    End Sub
    Private Function CreatLineType(ByVal LineTypeName As String) As ObjectId
        Dim LineTypeID As ObjectId
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Using trans As Transaction = db.TransactionManager.StartTransaction
            Dim it As LinetypeTable = trans.GetObject(db.LinetypeTableId, OpenMode.ForRead)
            If it.Has(LineTypeName) Then
                LineTypeID = it.Item(LineTypeName)
            Else
                db.LoadLineTypeFile(LineTypeName, "acadiso.lin")
                Dim ltr As New LinetypeTableRecord
                ltr.Name = LineTypeName
                it.UpgradeOpen()
                LineTypeID = it.Add(ltr)
                trans.AddNewlyCreatedDBObject(ltr, True)
            End If
trans.Commit()
        End Using
        Return LineTypeID
    End Function
发表于 2007-5-22 13:28:00 | 显示全部楼层
 OpenMode.ForRead 改为OpenMode.ForWrite
没有测试过,只是看见这个地方有问题
GMT+8, 2025-5-13 18:36 , Processed in 0.165891 second(s), 23 queries , Gzip On.
