(defun c:yyf1() (if (> (setq index3_3 (load_dialog "yeyacad/dcls/yyf1.dcl")) 0) (progn (if (new_dialog "yyf1" index3_3) (progn (action_tile "hsf" "(hxf1)") (action_tile "ylf" "(ylf1)") (action_tile "llkzf" "(llkzf1)") (action_tile "sxf" "(sxf1)") (action_tile "dxf" "(dxf1)") (start_dialog) (unload_dialog index3_3) ) (alert "不能正常显示对话框。") ) ) (alert "不能载入DCL文件。") ) ) (defun xs1() (start_list "hxflist") (if (= (setq d1 (open (findfile "YEYACAD/wenbens/hxf.txt") "r")) nil) (alert "文件不存在或不能打开。") (progn (setq clbb '()) (while (setq str (read-line d1)) (add_list str) (setq clbb (cons str clbb)) ) (close d1) ) ) (end_list) (setq dang1 nil) (mode_tile "hxflist" 2) (set_tile "hxflist" "0") ) (defun xs2() (start_list "ylflist") (if (= (setq d2 (open (findfile "YEYACAD/wenbens/ylf.txt") "r")) nil) (alert "文件不存在或不能打开。") (progn (setq clbb '()) (while (setq str (read-line d2)) (add_list str) (setq clbb (cons str clbb)) ) (close 2) ) ) (end_list) (setq d2 nil) (mode_tile "ylflist" 2) (set_tile "ylflist" "0") ) (defun xs3() (start_list "llkzflist") (if (= (setq d3 (open (findfile "YEYACAD/wenbens/llkzf.txt") "r")) nil) (alert "文件不存在或不能打开。") (progn (setq clbb '()) (while (setq str (read-line d3)) (add_list str) (setq clbb (cons str clbb)) ) (close d3) ) ) (end_list) (setq d3 nil) (mode_tile "llkzflist" 2) (set_tile "llkzflist" "0") ) (defun xs4() (start_list "sxflist") (if (= (setq d4 (open (findfile "YEYACAD/wenbens/sxf.txt") "r")) nil) (alert "文件不存在或不能打开。") (progn (setq clbb '()) (while (setq str (read-line d4)) (add_list str) (setq clbb (cons str clbb)) ) (close d4) ) ) (end_list) (setq d4 nil) (mode_tile "sxflist" 2) (set_tile "sxflist" "0") )
