对于点位计算,还是不大简练,作为设计,应当将点位图绘制出来,以便更好讨论。
;;定义本程序并声明变量
(defun
C:TT
(setq
SS
(ssadd))
(setq
CP
'(0
0))
(setq
PT1
260)
(setq
PT2
245)
(setq
PT5
234)
(setq
PT6
220)
(setq
PT9
210)
(setq
PT10
53)
(setq
PT11
55)
(setq
CP0
(list
0
0))
(setq
OS
(getvar
"osmode"))
(setvar
"osmode"
0)
;;为六个螺钉(右左中的顺序)的中心赋值
(setq
P1
(list
(car
CP)
PT11)
(cadr
CP)
PT5
2)))
P2
(list
(car
CP)
PT10)
(cadr
CP)
PT5
2)))
P3
(list
(car
CP)
(cadr
CP)
PT5
2)))
(command
"_.layer"
"m"
0
"on"
;;绘制外长方形
(command
"_.rectang"
(list
(car
CP)
PT2
2))
(cadr
CP)
PT1
2)))
(list
(car
CP)
PT2
2))
(cadr
CP)
PT1
2)))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
;;绘制螺钉内圆(右左中的顺序)
(command
"_.circle"
P1
"D"
"20")
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.circle"
P2
"D"
"20")
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.circle"
P3
"D"
"20")
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制螺钉外六边形(右左中的顺序)
(command
"_.polygon"
6
P1
"c"
"10")
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.polygon"
6
P2
"c"
"10")
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.polygon"
6
P3
"c"
"10")
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制两个边缘孔
(command
"_.circle"
(list
(car
CP)
PT9
2))
(cadr
CP)
PT6
2)))
"D"
"13"
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.circle"
(list
(car
CP)
PT9
2))
(cadr
CP)
PT6
2)))
"D"
"13"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制上方1横向的直线
(command
"_.line"
(list
(car
CP)
PT2
2))
(cadr
CP)
PT1
2)
44))
(list
(car
CP)
PT2
2))
(cadr
CP)
PT1
2)
44))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制上方2横向的直线
(command
"_.line"
(list
(car
CP)
PT2
2))
35)
(cadr
CP)
40))
(list
(car
CP)
PT2
2))
35)
(cadr
CP)
40))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制左边垂直线
(command
"_.line"
(list
(car
CP)
PT2
2)
35))
(cadr
CP)
PT1
2)
44))
(list
(car
CP)
PT2
2)
35))
(cadr
CP)
PT1
2)
44))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@0,10"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制右上方螺钉两边的直线(最右端1)
(command
"_.line"
(list
(car
CP)
PT11)
18)
(cadr
CP)
PT1
2)))
(list
(car
CP)
PT11)
18)
(cadr
CP)
PT1
2)
44))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;(从右到左2)
(command
"_.line"
(list
(car
CP)
PT11)
18)
(cadr
CP)
PT1
2)))
(list
(car
CP)
PT11)
18)
(cadr
CP)
PT1
2)
44))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;(从右到左3)
(command
"_.line"
(list
(car
CP)
18)
(cadr
CP)
PT1
2)))
(list
(car
CP)
18)
(cadr
CP)
PT1
2)
44)))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;(从右到左4)
(command
"_.line"
(list
(car
CP)
18)
(cadr
CP)
PT1
2)))
(list
(car
CP)
18)
(cadr
CP)
PT1
2)
44)))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;(从右到左5)
(command
"_.line"
(list
(car
CP)
PT10)
18)
(cadr
CP)
PT1
2)))
(list
(car
CP)
PT10)
18)
(cadr
CP)
PT1
2)
44))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;(从右到左6)
(command
"_.line"
(list
(car
CP)
PT10)
18)
(cadr
CP)
PT1
2)))
(list
(car
CP)
PT10)
18)
(cadr
CP)
PT1
2)
44))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制左上长方形
(command
"_.rectang"
(list
(car
CP)
PT2
2))
8)
(cadr
CP)
17))
(list
(car
CP)
PT2
2)
27))
(cadr
CP)
PT1
2)
55))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制右上长方形
(command
"_.rectang"
(list
(car
CP)
PT2
2))
8)
(cadr
CP)
17))
(list
(car
CP)
PT2
2))
27)
(cadr
CP)
PT1
2)
55))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制中间两个孔(左内)
(command
"_.circle"
(list
(car
CP)
PT9
2))
70)
(cadr
CP))
"D"
"26"
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@0,10"
(setq
SS
(ssadd
(entlast)
SS))
;;(左外)
(command
"_.circle"
(list
(car
CP)
PT9
2))
70)
(cadr
CP))
"D"
"30"
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@0,10"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制中心线,每绘制一条就移动到用户指定位置
(command
"_.layer"
"m"
1
"on"
(command
"_.line"
(list
(car
CP)
PT2
2)
3)
(cadr
CP))
(list
(car
CP)
PT2
2)
3)
(cadr
CP))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.line"
(list
(car
CP)
(cadr
CP)
PT1
2)
3))
(list
(car
CP)
(cadr
CP)
PT1
2)
3))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
;;绘制中间两个孔竖直方向中心线
(command
"_.line"
(list
(car
CP)
PT9
2))
70)
(cadr
CP)
18))
(list
(car
CP)
PT9
2))
70)
(cadr
CP)
18))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@0,10"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制上方两个边缘孔水平方向中心线(左)
(command
"_.line"
(list
(car
CP)
PT9
2)
10)
(cadr
CP)
PT6
2)))
(list
(car
CP)
PT9
2))
10)
(cadr
CP)
PT6
2))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
;;绘制上方两个边缘孔水平方向中心线(右)
(command
"_.line"
(list
(car
CP)
PT9
2)
10)
(cadr
CP)
PT6
2)))
(list
(car
CP)
PT9
2))
10)
(cadr
CP)
PT6
2))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
;;绘制上方两个边缘孔竖直方向中心线(左)
(command
"_.line"
(list
(car
CP)
PT9
2))
(cadr
CP)
PT6
2)
10))
(list
(car
CP)
PT9
2))
(cadr
CP)
PT6
2))
10)
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
;;绘制上方两个边缘孔竖直方向中心线(右)
(command
"_.line"
(list
(car
CP)
PT9
2))
(cadr
CP)
PT6
2)
10))
(list
(car
CP)
PT9
2))
(cadr
CP)
PT6
2))
10)
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
;;绘制上方螺钉孔中心线(水平方向)
(command
"_.line"
(list
(car
CP)
PT10
15)
(cadr
CP)
PT5
2)))
(list
(car
CP)
PT11
15)
(cadr
CP)
PT5
2)))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制上方螺钉孔中心线竖直方向(左1)
(command
"_.line"
(list
(car
CP)
PT10)
(cadr
CP)
PT1
2)
3))
(list
(car
CP)
PT10)
(cadr
CP)
PT1
2)
47)))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
;;绘制上方螺钉孔中心线竖直方向(右1)
(command
"_.line"
(list
(car
CP)
PT11)
(cadr
CP)
PT1
2)
3))
(list
(car
CP)
PT11)
(cadr
CP)
PT1
2)
47)))
(setq
SS
(ssadd
(entlast)
SS))
(command
"_.move"
(entlast)
CP0
CP)
(command
"_.mirror"
(entlast)
CP
"@10,0"
(setq
SS
(ssadd
(entlast)
SS))
(setvar
"osmode"
OS)
(command
"_.move"
SS
'(0
0)
PAUSE)
