不知怎么回事,lisp程序老是读不上对话框里,下拉式列表框里的数据!!!! 请知道的大哥们一定要帮帮忙!!!! dcl程序 clcs:dialog{ label="齿轮参数化设计"; :boxed_column{ label="设计参数选择"; :popup_list{ label="齿数比u="; key=pop1; edit_width=10; value=2; list="3\n3.1\n3.2\n3.3\n3.4\n3.5\n3.6\n3.7\n3.8\n3.9\n4"; } :popup_list{ label="初选小齿轮齿数z1="; key=pop2; edit_width=10; value=6; list="18\n19\n20\n21\n22\n23\n24\n25\n26\n27\n28\n29\n30"; } } ok_only; } lisp程序 (defun c:clcs () (setq osmode(getvar"osmode") cmdecho (getvar"cmdecho") blipmode(getvar"blipmode"));;将一些系统变量存储起来,以备图形绘出后恢复 (setvar"osmode" 0) (setvar "blipmode" 0) (setvar "CMDECHO" 0);;设定一些需要的系统变量 (vl-load-com) (setq dcl_id (load_dialog "c:/clcs.dcl")) (new_dialog "clcs" dcl_id) (action_tile "accept" "(getdata)(done_dialog)") (start_dialog) (unload_dialog dcl_id) (setq z2 (* u z1)) (prin1 z2)) (defun getdata () (action_tile "pop1" "(set_tile $key $value)") (setq z1 (atof(get_tile "pop1"))))
