查看: 1745|回复: 1
[求助]请问如何将数据发送到一打开的EXCEL表格?
发表于 2007-5-26 08:06:00 | 显示全部楼层 |阅读模式
选择一封闭的多段线,然后将其面积、长度数据分别发送到一打开的EXCEL表格的指定单元格(或活动单元格)
 楼主| 发表于 2007-5-26 23:57:00 | 显示全部楼层
我编了这几句,哪位朋友能帮我优化一下吗?
Sub CX()
    Dim uselect As AcadSelectionSet
    Dim mj As String, zc As String
    Dim Excelapplication As Excel.Application
    Dim Excelsheet As worksheet
    With ThisDrawing
        On Error Resume Next
         .SelectionSets("currentselection").Delete
          Set uselect = .SelectionSets.Add("currentselection")
          uselect.SelectOnScreen
          For Each objselect In uselect
              mj = objselect.Area
              zc = objselect.Length
              Next
        '  MsgBox "面积= " & mj & " !", vbInformation    '信息框
    End With
        Set Excelapplication = New Excel.Application
            Excelapplication.Visible = True 'False
            Excelapplication.workbooks.Add
        Set Excelsheet = Excelapplication.activeworkbook.sheets("sheet1")
            Excelsheet.cells(1, 1).Value = "面积"
            Excelsheet.cells(1, 2).Value = "周长"
            Excelsheet.cells(2, 1).Value = mj
            Excelsheet.cells(2, 2).Value = zc
End Sub
GMT+8, 2025-5-2 09:16 , Processed in 0.170719 second(s), 23 queries , Gzip On.
