麻烦哪位大哥 帮我看一下 此程序在05版的AutoCAD中运行 每次运行的结果都会有差异 反复看了程序没有 问题 是不是 我的软件有问题 如果是 可有补丁程序? 谢谢^_^ zhoucheng2:dialog{ label="绘制深沟球轴承"; :popup_list{label="轴承型号"; key="key_type"; list="6200\n6201\n6202\n6203\n6204\n6205\n6206\n6207\n6208\n6209\n6210\n6211\n6212\n6213\n6214\n6215\n6216\n6217\n6218\n6219\n6220"; } ok_cancel; } (defun c:zhoucheng2() (setq return_value (load_dialog "zhoucheng2")) (setq what_next 2) (while (>= what_next 2) (if (null (new_dialog "zhoucheng2" return_value)) (exit)) (initial) (action_tile "accept" "(getdata) (done_dialog 1)") (setq what_next (start_dialog)) (if (= what_next 1) (draw)) ) (unload_dialog return_value) (princ) ) (defun initial() (setq data_6200_list (list "10" "30" "9")) (setq data_6201_list (list "12" "32" "10")) (setq data_6202_list (list "15" "35" "11")) (setq data_6203_list (list "17" "40" "12")) (setq data_6204_list (list "20" "47" "14")) (setq data_6205_list (list "25" "52" "15")) (setq data_6206_list (list "30" "62" "16")) (setq data_6207_list (list "35" "72" "17")) (setq data_6208_list (list "40" "80" "18")) (setq data_6209_list (list "45" "85" "19")) (setq data_6210_list (list "50" "90" "20")) (setq data_6211_list (list "55" "100" "21")) (setq data_6212_list (list "60" "110" "22")) (setq data_6213_list (list "65" "120" "23")) (setq data_6214_list (list "70" "125" "24")) (setq data_6215_list (list "75" "130" "25")) (setq data_6216_list (list "80" "140" "26")) (setq data_6217_list (list "85" "150" "28")) (setq data_6218_list (list "90" "160" "30")) (setq data_6219_list (list "95" "170" "32")) (setq data_6220_list (list "100" "180" "34")) ) (defun getdata() (setq m_type (get_tile "key_type")) (setq m_type (atoi m_type)) (setq data_list (eval (read (strcat "data_" (nth m_type (list "6200" "6201" "6202" "6203" "6204" "6205" "6206" "6207" "6208" "6209" "6210" "6211" "6212" "6213" "6214" "6215" "6216" "6217" "6218" "6219" "6220")) "_list")))) (setq nd (nth 0 data_list)) (setq nd (atoi nd)) (setq wd (nth 1 data_list)) (setq wd (atoi wd)) (setq b (nth 2 data_list)) (setq b (atoi b)) ) (defun draw() (command "layer" "m" "0" "ON" "0" "L" "continuous" "0" "") (setq r (/ (- wd nd) 8)) (command "pline" (setq p1 (list 0 0)) (setq p2 (polar p1 0 b)) (setq p3 (polar p2 (/ pi -2) (- (* 2 r) (/ r 2)))) (setq p4 (polar p3 pi (/ (- b (* r (sqrt 3))) 2))) "a" "d" "120" (setq p5 (polar p4 pi (* r (sqrt 3)))) "l" (setq p6 (polar p5 pi (/ (- b (* r (sqrt 3))) 2))) "c" ) (setq object (entlast)) (command "hatch" "ansi31" "" "0" object "") (setq pt (polar p1 (/ pi -2) (* 2 r))) (setq pz11 (polar pt pi 1.5)) (setq pz12 (polar pz11 0 (+ 3 b))) (setq ss (ssget "X" (list (cons 8 "0")))) (command "mirror" ss "" pz11 pz12 "") (setq cir (list (/ b 2) (* r -2 ))) (command "circle" cir r) (setq pz21 (polar p1 (* pi -0.5) (/ wd 2))) (setq pz22 (polar p2 (* pi -0.5) (/ wd 2))) (command "line" p1 pz21 "") (command "line" p2 pz22 "") (setq ss (ssget "X" (list (cons 8 "0")))) (command "mirror" ss "" pz21 pz22 "") (princ) )
