查看: 1246|回复: 2
大家帮个忙
发表于 2007-5-27 08:32:00 | 显示全部楼层 |阅读模式
我是新人!刚学visual lisp想写一很简单的程序
(defun getdata()
    (setq x (atof(get_tile "X")))
    (setq y (atof(get_tile "Y")))
    (setq z1 (+ x y))
    (setq z (itoa z1))
    (set_tile "Z" z)
(defun c:add (/ x y z z1 id sdt )
  (setq sdt 0)
  (setq id(load_dialog "C:/Documents and Settings/LuckyStar/我的文档/add.DCL"))
  (if (< id 0)(exit))
  (setq x 0 y 0)
  (if (not (new_dialog "add" id ))(exit))
  (set_tile "X" "")
  (set_tile "Y" "")
  (set_tile "Z" "")
  (action_tile "accept" "(getdata)")
  (action_tile "cancel" "(done_dialog -1)")
  (setq sdt (start_dialog))
  (unload_dialog id)
只要按确定键时能自动计算X+Y=Z,并在Z的窗口显示,可是老是说“参数类型错误: fixnump”
谁能帮忙说说明下是为什么
发表于 2007-5-27 10:32:00 | 显示全部楼层
(defun getdata()
    (setq z1 (+ x y))
    (setq z (itoa z1))
z1为整数时,才能使用 itoa ,
改为:
    (setq z1 (+ x y))
    (setq z (itoa (fix z1)))
或改为:
    (setq z1 (+ x y))
    (setq z (rtos z1 2 2))
 楼主| 发表于 2007-5-27 21:39:00 | 显示全部楼层
xiexie
GMT+8, 2026-1-20 04:23 , Processed in 0.750148 second(s), 25 queries , Gzip On.
