查看: 1992|回复: 0
[原创]三点的外接圆内切圆和九点圆函数
发表于 2007-5-31 11:57:00 | 显示全部楼层 |阅读模式
三点的外接圆,内切圆,和九点圆如果用CAD的画圆命令来说很容易,但是对于那些不希望用命令的场合下,VB就需要编写一个函数了。
下面是我写的,初次学VBA,望各位多多指教
  1. Option Explicit
  2. Const Pi = 3.14159265358979
  3. Public Sub drawCircle()
  4.   Dim pt1, pt2, pt3, Mp1, Mp2, Mp3 As Variant
  5.   Dim CirObj As AcadCircle
  6.   Dim CIR1, CIR2 As Variant
  7.
  8.   On Error Resume Next
  9.
  10.   '数据输入
  11.   pt1 = ThisDrawing.Utility.GetPoint(, vbCr & "请输入圆的第一点:")
  12.   pt2 = ThisDrawing.Utility.GetPoint(, vbCr & "请输入圆的第二点:")
  13.   pt3 = ThisDrawing.Utility.GetPoint(, vbCr & "请输入圆的第三点:")
  14.   '三边长的中点
  15.   Mp1 = Midpt(pt2, pt3)
  16.   Mp2 = Midpt(pt3, pt1)
  17.   Mp3 = Midpt(pt1, pt2)
  18.   '求得结果
  19.   CIR1 = ThreePointCircle(pt1, pt2, pt3)
  20.   CIR2 = ThreePointCircle(Mp1, Mp2, Mp3)
  21.   '画圆
  22.   Set CirObj = ThisDrawing.ModelSpace.AddCircle(CIR1(0), CIR1(1)) '画外接圆
  23.   Set CirObj = ThisDrawing.ModelSpace.AddCircle(CIR1(2), CIR1(3)) '画内切圆
  24.   Set CirObj = ThisDrawing.ModelSpace.AddCircle(CIR2(0), CIR2(1)) '画九点圆
  25.
  26. End Sub
  27. Function ThreePointCircle(ByVal ptA, ptB, ptC As Variant) As Variant
  28.   Dim a, b, c, p, Rad1, Rad2 As Double
  29.   Dim TanHalfA, AngleofA, xA, xB, xC, H_AA As Double
  30.   Dim ptAM, ptAT, Cen1, Cen2 As Variant
  31.   Dim HPi, Direct As Double
  32.   Dim CircleList(0 To 4) As Variant
  33.   HPi = Pi / 2
  34.
  35.   '三边边长
  36.   a = Distance(ptB, ptC)                                                           'A边边长
  37.   b = Distance(ptC, ptA)                                                           'B边边长
  38.   c = Distance(ptA, ptB)                                                            'C边边长
  39.   '边X轴角
  40.   xA = ThisDrawing.Utility.AngleFromXAxis(ptB, ptC)                 'A边X轴角
  41.   xB = ThisDrawing.Utility.AngleFromXAxis(ptC, ptA)                 'B边X轴角
  42.   xC = ThisDrawing.Utility.AngleFromXAxis(ptA, ptB)                 'C边X轴角
  43.
  44.   '下面的判断必不可少,否则会出错
  45.   Direct = Delta(ptA, ptB, ptC)
  46.   If Direct < 0 Then
  47.     HPi = -HPi
  48.   End If
  49.
  50.   '开始计算
  51.   If Abs(Sin(xA - xB) * Sin(xB - xC) * Sin(xC - xA)) < 0.00000001 Then
  52.     MsgBox "你输入的三点在同一条直线上!", vbOKOnly, "出错警告"
  53.   Else
  54.     p = (a + b + c) / 2        '半周长
  55.     TanHalfA = Sqr((p - b) * (p - c) / (p * (p - a)))                         '半角A的正切值
  56.     AngleofA = 2 * Atn(TanHalfA)                                                 '角A
  57.     '外接圆
  58.     ptAM = ThisDrawing.Utility.PolarPoint(ptB, xA, a / 2)               'A边中点
  59.     H_AA = a * tan(HPi - AngleofA) / 2                                          'A边弦高
  60.     Cen1 = ThisDrawing.Utility.PolarPoint(ptAM, xA + HPi, H_AA) '外接圆圆心
  61.     Rad1 = Distance(ptA, Cen1)                                                   '外接圆半径
  62.     '内切圆
  63.     ptAT = ThisDrawing.Utility.PolarPoint(ptA, xC, p - a)               'C边内切点
  64.     Rad2 = Sqr((p - a) * (p - b) * (p - c) / p)                                   '内切圆半径
  65.     Cen2 = ThisDrawing.Utility.PolarPoint(ptAT, xC + HPi, Rad2)  '内切圆圆心
  66.   End If
  67.
  68.   CircleList(0) = Cen1
  69.   CircleList(1) = Rad1
  70.   CircleList(2) = Cen2
  71.   CircleList(3) = Rad2
  72.
  73.   ThreePointCircle = CircleList
  74.
  75. End Function
  76. '距离函数
  77. Function Distance(pt1, pt2 As Variant) As Double
  78.   Dim x, y, z As Double
  79.   x = pt1(0) - pt2(0)
  80.   y = pt1(1) - pt2(1)
  81.   z = pt1(2) - pt2(2)
  82.   Distance = Sqr(x ^ 2 + y ^ 2 + z ^ 2)
  83. End Function
  84. '三点形成的左右拐的判定
  85. Function Delta(pt1, pt2, pt3 As Variant) As Double
  86.   Dim dx1, dy1, dx2, dy2 As Double
  87.   dx1 = pt2(0) - pt1(0)
  88.   dy1 = pt2(1) - pt1(1)
  89.   dx2 = pt3(0) - pt1(0)
  90.   dy2 = pt3(1) - pt1(1)
  91.   Delta = dx1 * dy2 - dx2 * dy1
  92. End Function
  93. '中点函数
  94. Function Midpt(pt1, pt2 As Variant) As Variant
  95.   Dim vv(0 To 2) As Double
  96.   vv(0) = (pt1(0) + pt2(0)) / 2
  97.   vv(1) = (pt1(1) + pt2(1)) / 2
  98.   vv(2) = (pt1(2) + pt2(2)) / 2
  99.   Midpt = vv
  100. End Function
GMT+8, 2025-10-13 04:08 , Processed in 0.155381 second(s), 24 queries , Gzip On.
