查看: 1475|回复: 2
请问如何把函数中绘制的一条多线段的名称传回来
发表于 2007-5-31 16:47:00 | 显示全部楼层 |阅读模式
我调用了Draw_Box_Center绘制了一条多线段,我想在函数外中使用该多线段,比如说调用该多线段的的Coordinate属性。
我的代码如下,运行时出现“参数不可选”的错误提示
 Call Draw_Box_Center("body_back_1", "Body_Layer", start_center_point_X, start_center_point_Y, L1, H1)
    Dim point1(0 To 1) As Double
    point1(0) = Draw_Box_Center.Coordinate(0)(0)
    point1(1) = Draw_Box_Center.Coordinate(0)(1)
Public Function Draw_Box_Center(box_name, layer_name, center_point_X, center_point_Y, box_long, box_width)
' Define the 2D polyline points
    Dim first_point_X As Double
    Dim first_point_Y As Double
    Dim points(0 To 9) As Double
    first_point_X = center_point_X - box_long / 2
    first_point_Y = center_point_Y - box_width / 2
    points(0) = first_point_X: points(1) = first_point_Y
    points(2) = first_point_X + box_long: points(3) = first_point_Y
    points(4) = first_point_X + box_long: points(5) = first_point_Y + box_width
    points(6) = first_point_X: points(7) = first_point_Y + box_width
    points(8) = first_point_X: points(9) = first_point_Y
     ' Create a lightweight Polyline object in model space
    Set box_name = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    Draw_Box_Center = box_name
    ' Set the layer of new circle to "ABC"
    box_name.layer = layer_name
End Function
发表于 2007-6-2 09:01:00 | 显示全部楼层
Public Function Draw_Box_Center(box_name, layer_name, center_point_X, center_point_Y, box_long, box_width) as string
Draw_Box_Center=box_name.objecthandle
end function
 楼主| 发表于 2007-6-2 12:00:00 | 显示全部楼层
sealive发表于2007-6-2 9:01:00Public Function Draw_Box_Center(box_name, layer_name, center_point_X, center_point_Y, box_long, box_width) as stringDraw_Box_Center=box_name.objecthandleend function
THANKS A LOT!!!
我用另一种方法实现了,
谢谢你的回答~~
GMT+8, 2025-10-13 04:14 , Processed in 0.151648 second(s), 23 queries , Gzip On.
